Date: 21-03-26  Time: 04:19 am
Author Topic: Idle compare  (Read 1580 times)
kgjersda
Idle compare
« on: 04 May 2017, 09:42:35 am »
Hello,
How would you compare my running idle with an optimal setting?
I have tried balancing the carbs, the spark plugs are very new (NKG CR9E).
(How do I embed video?)
Bretty
Re: Idle compare
« Reply #1 on: 04 May 2017, 11:04:40 am »
Mines probably the same cold and super smooth when warmed up after a good motorway run.
Just turn up the tickover on the carbs a notch if it bothers you.
someone will be along in a minute to suggest you check or renew your air filter, although you're meant to do that before you balance the carbs.
kgjersda
Re: Idle compare
« Reply #2 on: 04 May 2017, 11:21:03 am »
Ah yes, forgot to mention that I already changed for a new DNA air filter.
Thanks for confirming that it's around where it should be :)
Jamieg285
Re: Idle compare
« Reply #3 on: 04 May 2017, 12:33:40 pm »
TBH, I can't really see much of an issue there.  I slight flutter, but nothing serious.  - How much time do you spend idling vs riding?
If it was me, I'd have been more of a perfectionist and got closer on the carb balance, but I'd say you were within acceptable levels.
