Date: 15-03-26  Time: 04:04 am
Author Topic: Drive shaft play fz6 s2 2009  (Read 4228 times)
PuddingLauncher
« on: 21 April 2017, 09:01:30 am »
Hi I'm trying to find out how much play there should  be in my driveshaft. ( the thing the front sprocket is connected to) as I am experiencing a kind of bouncing when I roll on and off the throttle as if my chain was way too loose. Chain tension is definatley fine (45mm at tightest spot). Also there is a popping sound when the 'slack' is taken up i.e accelerating hard or under engine breaking. My chain and sprockets do need replacing so I'm hoping their worn state is exagerating the effect of the hopefully normal play in the driveshaft. There seems to be more play in 1st and 2nd and less in all the other gears. Also people tell me my bike smells of clutch but I cant smell it. Anyone have experience of this? Thanks for any advice you can give.
Bretty
Re: Drive shaft play fz6 s2 2009
« Reply #1 on: 21 April 2017, 10:43:24 am »
I don't think there should be any axial or radial play in the shaft itself.. Not that you would be able to tell, as the shaft seals are too tight.
Rotational play can be caused by various things, worn sprocket? Chain tension? Or an issue with the clutch adjustment or gearbox.
Although you say the chain is fine, and clutch and gearbox faults are usually more noticeable in other ways. Slipping clutch is obvious, so is the gearbox crashing or jumping out of gear.
PuddingLauncher
« Reply #2 on: 21 April 2017, 11:00:50 am »
Thanks for the reply. If I have the bike on the center stand in gear I can rotatate the rear wheel back and forth. This movement can be seen in the driveshaft with the cover off. It's about 2 teeth of movement on the front sprocket. I have read that other bikes do have driveshaft play but I'm not sure what is normal for my fazer.
« Reply #3 on: 21 April 2017, 11:15:42 am »
My FZS600 has one tooth's-worth of rotational play and the motor has well over 100,000 miles on it.
Two teeth sounds excessive, but it's a different engine... hopefully someone with another FZ6 will be able to confirm what is normal.
PuddingLauncher
« Reply #4 on: 21 April 2017, 08:21:19 pm »
Thanks for your replies. I think I will replace the chain and sprockets and see what it is like then.
« Reply #5 on: 21 April 2017, 08:51:13 pm »
Is 45mm at the tightest spot correct?
Sounds like a lot of chain slack to me, but i don't actually know what's correct for your bike?
PuddingLauncher
« Reply #6 on: 21 April 2017, 09:48:17 pm »
Yes it says 45mm to 55mm in the haynes manual and also the bike manual. 45mm doesn't leave much play in it with me sat on it though. So if anything it's a little on the tight side.
