Date: 21-03-26  Time: 04:18 am
Author Topic: Running like a dog  (Read 4320 times)
Koreanbaz
Running like a dog
« on: 16 April 2017, 06:31:36 pm »
after messing with fuel tank sender issues. Bike is now running on three cylinders.
Changed the plugs as you do.
No better. Looks like a disturbance somewhere. Or the carb rebuild wasn't as good as suggested.  :eek
daviee
  • Guest
Re: Running like a dog
« Reply #1 on: 16 April 2017, 07:13:35 pm »
did you do both at the same time carb clean and sender ? are you getting a spark on that cylinder ?
pointer2null
« Reply #2 on: 16 April 2017, 09:02:27 pm »
Check you haven't kinked the breather tubes.
Bretty
« Reply #3 on: 17 April 2017, 10:08:31 am »
Firing on three - determine which cylinder has the issue by the temperature of the down pipes (put some spit on it).
switch the spark plug caps over swap 1 with 4 and 2 with 3. See if the problem moves. If it moves it's an electrical fault if it doesn't it's a carb/fuel fault.
Jules-C
« Reply #4 on: 17 April 2017, 10:30:02 pm »
Or a spark plug fault.  If fault stays in same place after swapping leads over try swapping spark plug with the one next to it and see if fault moves with the plug
pointer2null
« Reply #5 on: 18 April 2017, 08:07:05 am »
Start where you last disturbed thing - playing with the tank sender unit shouldn't affect plugs etc. Check the easy of obvious first. Then move on.
Moving the tank could also disturb water and crud from the bottom. The fule filter should take care of most of th crud. Ethanol (meths) will absorb water if added to the fuel.
Bretty
« Reply #6 on: 18 April 2017, 10:10:10 am »
Although the OP did say they had changed the spark plugs.
Koreanbaz
« Reply #7 on: 23 April 2017, 05:08:07 pm »
Spark plugs were changed first.
Removed tank, no obvious issues.
Removed carbs to see what has been done. Someone has been inside as there are scratch marks in the bowls.
Rubbers to the manifold, have a few cracks. But nothing seems to be right through. Like was suggested they would be ok on here
Carbs 4 and 3 seperated, just awaiting ultrasonic cleaning fluid. Then I shall do each carb one at a time.
I think, but I need to confirm, that three of the four pilot jets are blocked.
No carburettor expert here. But I'm lead to believe they are the issue for idling.
Koreanbaz
« Reply #8 on: 24 April 2017, 04:01:39 pm »
A bit more cleaning today as I'm on-call.
Removed fuel tap. It was full of shit.
Emptied all the fuel out and that was also full of rust from the fuel tank.
Washed the tank out. Now filled with vinegar for a few days whilst the cleaning fluid rocks up.
crickleymal
« Reply #9 on: 25 April 2017, 01:11:14 pm »
Why?
BBROWN1664
« Reply #10 on: 25 April 2017, 04:21:59 pm »
Running like a dog
Is it only me that sees the funny side of this post from a poster by the name of  Koreanbaz?
daviee
  • Guest
« Reply #11 on: 25 April 2017, 05:39:11 pm »
Running like a dog
the place where dogs run the fastest lol
Bretty
« Reply #12 on: 25 April 2017, 09:02:43 pm »
Nothing wrong with Korea. Especially the food!
I hear their meatballs are the dogs bollocks!
Koreanbaz
« Reply #13 on: 06 May 2017, 08:53:47 pm »
Running like a dog
Maybe it should have been "running like my dinner!"
