Date: 04-03-26  Time: 16:56 pm
Author Topic: Fazer 2004 Gen 1 Oil Cap Issue  (Read 2058 times)
hopskimoet
« on: 09 April 2017, 07:02:28 pm »
Just recently purchased a FZS1000 2004 (23K) and during riding there is weepage at the oil filler cap. At first, I thought a gasket had failed as the oil was collecting under the clutch cover. I have tightened the oil filler cap as tight as it will go and still she weeps. I was thinking maybe a quick fix by using a few layers of PTFE (plumber's tape) as it does offer good heat resistance. Is this an inherent issue or is it something unique and an indicator of a deeper problem?
slappy
Re: Fazer 2004 Gen 1 Oil Cap Issue
« Reply #1 on: 09 April 2017, 07:19:10 pm »
There should be an 'O' ring fitted to the cap, check it is there / not damaged.
hopskimoet
« Reply #2 on: 09 April 2017, 07:24:55 pm »
Of course... I'll check it... Is the washer bike specific? Or can I just use one from a kit?
slappy
« Reply #3 on: 09 April 2017, 08:57:22 pm »
As long as the 'O' ring is a reasonably tight fit on the cap then any one will do.
hopskimoet
« Reply #4 on: 20 April 2017, 10:55:49 am »
Sorted. The 'O' ring was missing. Ordered one from Fowlers for £7 although I could have just used one from a standard kit. No drama though. Does anyone know what color silver I need to touch up the engine?
robbo
« Reply #5 on: 20 April 2017, 01:25:44 pm »
RS Paints will have the necessary engine and bodywork paints .Just input your make/model/year. However other members have used alternative sources.A search will give you those answers. :)
PieEater
« Reply #6 on: 20 April 2017, 01:34:47 pm »
As will checking out the FAQ  :D
