Date: 10-02-26  Time: 12:10 pm
Author Topic: Am I missing something?!  (Read 4268 times)
Skippernick
« on: 04 April 2017, 07:28:29 pm »
I have just performed a coolant change and something under the tank got me confused.
I have 3 fitting ones with the isolation valve and 2 others which have a pipe loop between them over the rubber drip catcher?
I don't think this is right but as i have never had a problem fuel wise i am confused. The tank gurgles quite a bit though!
Some one explain to me if this is right.
Re: Am I missing something?!
« Reply #1 on: 04 April 2017, 07:45:40 pm »
3 fitting ones what?
You've lost me?
« Reply #2 on: 04 April 2017, 07:46:50 pm »
i have been looking at this myself - i think it could be a overflow outlet maybe - i dont have a link pipe on mine though they are just open
« Reply #3 on: 04 April 2017, 07:58:09 pm »
Are you on about the two little pipes under the fuel tank?
If so one is an air breather that goes through the tank up to the cap, the other is an overflow pipe for fuel, or any rain that may pass the outer cap. The hole is on the left side for when the bike's on the sidestand.
« Reply #4 on: 04 April 2017, 08:01:24 pm »
If they're both looped then your tank isn't breathing properly at all, whatever is looping them needs removing.
Skippernick
« Reply #5 on: 04 April 2017, 08:29:06 pm »
Sorry tried to upload a pic but it was to big.
On the underside of the tank there are 3 fittings. One supplies the fuel to the carbs, the other 2 are right next to each other with a piece of rubber pipe joining the 2 fittings together. They are located on the right side of the tank facing forward above a rubber funnel for want of a better description.
« Reply #6 on: 04 April 2017, 08:35:43 pm »
Yeah, vent and overspill.
Shouldn't be joined at all.
On 98/99 bikes they have pipes coming off them going down towards the floor, then the funnel was used instead to make things a bit neater i s'pose.
Skippernick
« Reply #7 on: 04 April 2017, 08:51:40 pm »
so i should just remove it, no need for the pipe on either.
I wonder if i put it on there when i removed the tank a couple of years ago, to prevent spillage.
« Reply #8 on: 04 April 2017, 08:54:26 pm »
Yeah they should be open.
Be careful one side isn't full of fuel from overflow.
Skippernick
« Reply #9 on: 04 April 2017, 08:59:47 pm »
cheers buddy,
bet my tank won't gurgle any more now as well.
« Reply #10 on: 04 April 2017, 09:09:42 pm »
cheers buddy,
 :lol
« Reply #11 on: 04 April 2017, 09:33:26 pm »
I suppose you could call one a fuel overflow, but it's really there to drain rainwater away from the filler cap area.
It's just as well yours never sees rain, though you could have introduced water to the tank when you wash the bike.
It'd be interesting to see what comes out when you take the link hose off.
« Reply #12 on: 04 April 2017, 11:54:16 pm »
interesting thought - if the 'funnel' catches what falls from that then where did the funnel pipe lead too - wasnt it into the airbox ??
just went to pods so i ripped everything out and threw it under a workbench
water into airbox wouldnt be a good thing
« Reply #13 on: 05 April 2017, 06:34:11 am »
Funnel pushes onto a drainage pipe that goes straight down towards the floor.
mogster
« Reply #14 on: 06 April 2017, 06:45:34 pm »
this is still needing breather pipe leading almost  out the bottom of the bike. i know this cos i didnt re attach mine and got told it affects the performance.
or is that the over flow leaking into the air box as Disorderly punk says; i still havent done mine :evil
« Reply #15 on: 07 April 2017, 06:43:13 am »
The necessity of the drainage pipe is simply because it is located to the right side of the bike if i remember correctly, which safely aims excess fuel away from the direct path of the rear tyre.
Skippernick
« Reply #16 on: 07 April 2017, 08:40:05 pm »
Well took the pipe off this evening, and about 10cc of runny white liquid came out!!!!
The tank stopped gurgling straight away as well  :)
« Reply #17 on: 07 April 2017, 09:14:37 pm »
We all love our Fazers, but most don't take it quite that far. :b
« Reply #18 on: 07 April 2017, 11:05:47 pm »
 :lol  Bike lit a snout up afterwards.  :smokin
