Date: 30-03-26  Time: 03:40 am
Author Topic: Should I be able to start the bike in gear with the clutch pulled in?  (Read 3036 times)
slinky2000
I'm pretty sure I used to be able to do this but it's not working at the moment.
If I'm in first gear (side stand up) and stall the bike, If I pull in the clutch, should I be able to start the bike?
At the moment if I do, the lights on the dash dim but it doesn't start, I have to put it into neutral and then start.
This is a bit of a pain at light sometimes.
Thanks.
joebloggs
If I'm in first gear (side stand up) and stall the bike, If In pull in the clutch should I be able to start the bike?
At the moment if I do the lights on the dash dim but it doesn't start, I have to put it into neutral and then start.
Thanks.
Sidestand switch?
slinky2000
Sidestand switch?
Actually should I be able to start the bike when on the side stand and in neutral?  Because I can't do that either.
Grayo
Sidestand switch?
Yes you should. Faulty sidestand switch you have there.
slinky2000
Perfect, I've already got one in the house. I'll fit it and see what happens.
Jules-C
The switch is a right **** to change.  I ended up cutting the old one to pieces to remove it.  Sometimes a good spray with wd40 or similar can get it working again
The lights shouldn't dim when you try and start it in gear since no power is going to the starter motor but from the other symptoms sounds like it is the sidestand switch.
joebloggs
Bypass the focer, please remember to raise it before setting off
That's what i ended up doing, it's in a ridiculously bad place to access.
