Date: 18-03-26  Time: 00:26 am
Author Topic: Down the pub - the thread about nothing and everything  (Read 226358 times)
Re: Down the pub - the thread about nothing and everything
« Reply #325 on: 05 June 2020, 06:18:40 pm »
I went to the optician today because I keep seeing the world fall apart.
He said I have 2020 vision.
« Reply #326 on: 19 June 2020, 07:34:32 am »
Look what I just saw on The Price Is Right.
Anyone on here win/own it?
It was on there at £5375.
« Reply #327 on: 19 June 2020, 09:29:57 am »
That is so bizarre. Also Dont think I have ever seen that colour scheme on any owners bikes on here
« Reply #328 on: 19 June 2020, 12:07:15 pm »
Yeah, it's just the gold version.
I can't believe the prizes on this show, which ran from 1995 to 2001.
In fact it had some of the biggest prizes ever on there, i can't thing of anything similar right now?
On at 5am though, but i'm up early every day so i see it most mornings now.  :lol
« Reply #329 on: 19 June 2020, 02:15:53 pm »
I thought only the red and black had that scheme and gold was just gold
YamFazFan
« Reply #330 on: 19 June 2020, 02:44:30 pm »
I bet that soon cleared the sleep from your eyes when that Fazer appeared on screen :lol
Well spotted. Is that the bloke that won it?.
« Reply #331 on: 20 June 2020, 05:43:53 am »
No, he's the shows male poser.
Dudeofrude
« Reply #332 on: 20 June 2020, 12:21:30 pm »
Sounds a bit sexist 🤔 must have been taking the job away from some scantily clad women with and orange face and overly white teeth 🤣
« Reply #333 on: 20 June 2020, 05:31:03 pm »
Not at all, they were all good lookers and not tampered with or creosoted either.  :lol
Dudeofrude
« Reply #334 on: 20 June 2020, 06:22:52 pm »
They were probably too old to get tampered with back in the 80s 🤭
« Reply #335 on: 27 July 2020, 10:40:59 pm »
So, who had "Baboons with Chainsaws" in the "What can 2020 throw at us next" Sweepstakes...?
« Reply #336 on: 11 August 2020, 10:36:22 am »
Maybe you're having a bad day, but I'm pretty sure you're not having a "tell your boss you set off the fire suppression system at the Minnesota National Guard hangar and foamed all 10 aircraft." kinda bad day...
« Reply #337 on: 11 August 2020, 12:23:47 pm »
Oops.
Open the doors and it will blow away then just rinse the airframes with fresh water and they should be good to go again.
« Reply #338 on: 11 August 2020, 12:35:07 pm »
Not quite that easy.  The engines will need to be stripped, flushed and run up as will the electronics systems, some foams turn into a sticky smelly mess although they may not be corrosive, they could react with some materials.  They may be no permanent damage but it's certainly not going to be a quick jet wash or hose down, many hours of work me thinks, someones for the high jump especially if it was a prank!
« Reply #339 on: 11 August 2020, 12:48:17 pm »
It will depend on the foam but in most cases you are correct. there is a newer foam out there that does just require a rinse down but......
A lot of time will be required to inspect the guts of the airframes to make sure no foam got in before any one can sign it off. the engines on those will just need an inspection as the whole thing including intakes and exhaust are above the foamline
« Reply #340 on: 11 August 2020, 01:04:43 pm »
Look at the height of the foam line on the two aircraft on the right and the one right at the back their engines are below or half way. mate  ;)
And here's the full picture
Error 404 (Not Found)!!1
Not  prank just a drill that went a bit further than they planned for  :rolleyes
« Reply #341 on: 11 August 2020, 02:14:51 pm »
:thumbup
« Reply #342 on: 11 August 2020, 06:23:58 pm »
And here's the full picture http://www.youtube.com/watch?v=mQe3PbWVuJE  ;)
Quite a bit further...!
I think some poor bugger is going to get told "Here's a teaspoon, start digging!"
[PS I tweaked the link on your post to fix it :thumbup ]
VNA - BMW Wank
« Reply #343 on: 11 August 2020, 08:48:13 pm »
I wouldn't like to be in there when that goes off.And surely there must be some sort of major foc-off warning before it goes off - give you a chance to run for your life.But then its the USA - maybe not. :eek
« Reply #344 on: 11 August 2020, 09:31:09 pm »
Never been in the situation myself but getting covered in the foam is OK, just keep the space in front of your face clear and you can break as the bubbles are full of air.
Several people have died when they have been caught in the foam though as they panicked and got disorientated and ultimately forgot to clear the space in front of their faces
VNA - BMW Wank
« Reply #345 on: 11 August 2020, 10:06:58 pm »
But it won't feed a fire?
And yeah it would be easy to panic in such a situation, and sometimes you'll never know until it happens - and then it could be too late.
I'm familiar with deluge systems.  They stress to us the active firing system must be disabled before you enter a protected area (there is still limited passive ambient temperature protection).  When it is on active, it will fire a whole zone of heads, and spray out absolute shit loads of water.  It suppresses the oxygen in the enviroment, to the extent it would be a threat to your well being - you might not get out.
coffee
« Reply #346 on: 12 August 2020, 10:31:34 pm »
Probably the same sort of scenario with a car going underwater,it must take a lot of bottle to sit and wait for the car to fill up before trying to open the windows. :eek
« Reply #347 on: 20 August 2020, 12:01:40 pm »
My 7 year old nephew showed me with pride the "telephone" he had just made from a string and two tin cans. I pulled out my iPhone and said, "That's nice, but..."
"Look at what kids your age make in China!
« Reply #348 on: 20 August 2020, 12:01:56 pm »
Phrases that mean nothing will happen:
Leave it with me
I’ll have a word
I’ll see what I can find
Consider it done!
I’ll make some calls
I’ll think about it
Certainly a possibility
Let’s come back to that
Good idea
Maybe
It’s on my list
Might see you down there
I’ll look into it
Oldgit
« Reply #349 on: 20 August 2020, 12:17:02 pm »
the foam of yesteryear contained bulls blood, and I have been caught not only in foam system discharges but deluges as well, sometimes inspecting them working and sometimes not.
