Date: 07-05-26  Time: 16:42 pm
Author Topic: Tail tidy  (Read 5735 times)
SutherlandFZS600
Tail tidy
« on: 10 March 2017, 01:27:46 pm »
Hi all!
Looking at fitting a tail tidy to the bike soon and just wondering who's got what and where from etc.. any help or info would be much appreciated cheers!!
Re: Tail tidy
« Reply #1 on: 10 March 2017, 01:41:22 pm »
Hi all!
I think I can say for everyone here that, no one has one for the FZS 600. Are you meaning and undertray ?, the best thing I think you can do - so long as you have a hugger is to move the numberplate up over the reflector right under the lights and cut off the mud guard flush, and then fit a reflector onto the numberplate, like in my picture - only this was before I fitted the reflector, I have also removed the grabrails and covered the holes. If you wanted to you could trim down the sides of the guard too but as you see in the picture I have left mine on the sides, but there is an ovious section begging to be cut off that you can see. Also if you were so inclined you could fit some tiny clear lens indicators but I am not a fan of small indicators.
ben17484
Re: Tail tidy
« Reply #2 on: 10 March 2017, 02:26:58 pm »
Hi all!
That looks nice.
SutherlandFZS600
Re: Tail tidy
« Reply #3 on: 10 March 2017, 03:23:35 pm »
Fazersharp your rear end looks lovely if you don't mind me saying so! :lol
Like what you have done with yours and has given me some ideas for mine!
Also doesn't cost a thing! Cheers for sharing the pic and what you have done fazersharp!
Really like the look of it! Top job fella!
SutherlandFZS600
Re: Tail tidy
« Reply #4 on: 10 March 2017, 03:26:44 pm »
Could even do away with reflector until MOT maybe? Just stick one on for test and take off again??
Re: Tail tidy
« Reply #5 on: 10 March 2017, 04:51:33 pm »
Or I think you can even get away with a 10pence sized stick on one that fits on your plate. And yes free to do, or not quite because you will need  a new plate because of the hole position, I used the same holes in the guard but got a new plate and drilled new holes in that.
Although the picture doesnt show but where the holes were for the grabrail I have covered with an oblong shape piece of black sticky back plastic with rounded ends but you can only see it if you are close, on a red bike you may have difficulty finding the exact colour - black is easy
F4celess
Re: Tail tidy
« Reply #6 on: 12 October 2017, 11:25:39 am »
I have an (aftermarket) colour matched Undertray plus CNC Tail Tidy fitted on my FZS600.
Flush looks MUCH cleaner. :eek Plus Jacked up, the SportIER rear end of the bike is greatly accentuated. :)
Re: Tail tidy
« Reply #7 on: 12 October 2017, 01:03:50 pm »
:useless
BBROWN1664
Re: Tail tidy
« Reply #8 on: 12 October 2017, 03:19:48 pm »
It may look good but removing the lower part of the existing tail will require a reflector to be put somewhere else.
Disorderlypunk
Re: Tail tidy
« Reply #9 on: 12 October 2017, 03:34:28 pm »
i removed my reflector trimmed the excess off the numberplate (instead of buying a smaller plate)
and lifted the whole thing up as far as i could - mot time i will just get one of those stick on reflectors
might buy a new numberplate and stick it too that then put it on once a year at mot time
F4celess
Re: Tail tidy
« Reply #10 on: 12 October 2017, 03:40:59 pm »
You buy ONE of those little round adhesive red reflectors (about the size of a 2p). Cost a pound or two off ebay, then stick it ON the numberplate.
If you were that bothered about cosmetics, you can always remove it for the other 364 days of the year.  ;)
It has to be exactly central too! A couple of years ago my bike (different bike) failed the MOT as, although I DID have a little stick-on reflector on the rear numberplate, it was positioned in the bottom corner, technically a fail.
BBROWN1664
Re: Tail tidy
« Reply #11 on: 12 October 2017, 03:43:09 pm »
If you buy TWO, put one in each corner and it is then legal.
F4celess
Re: Tail tidy
« Reply #12 on: 12 October 2017, 03:56:42 pm »
Not true. The official MOT Test states...
"Statutory reflectors
 Mopeds and motor bicycles require one unobscured red reflector which is aligned to the vehicles longitudinal centre line and is positioned to reflect squarely to the rear. If the motorcycle is fitted with a side car the side car will also require a reflector fitted towards the nearside and positioned to reflect squarely to the rear.
Extra reflectors fitted to a motorcycle are not included in this inspection.
One in each corner would still not meet the above requirement.
BBROWN1664
Re: Tail tidy
« Reply #13 on: 12 October 2017, 04:52:02 pm »
OK, so following the rules, fitted to the number plate will fail too due to it not being absolutely vertical. :pokefun
I have had bikes pass with a single one on one side of the plate before. Just depends on your testers anal retentiveness.
Re: Tail tidy
« Reply #14 on: 12 October 2017, 05:03:14 pm »
I have mine on a small bracket bolted in the centre of the mud guard about 1 inch up from the bottom edge which is cut flush with the lifted numberplate. On the bolt secured with a wing nut the bracket and reflector can swivel up behind the guard and when in the down potion is at the correct angle as the bracket is bent like that.
Because I am a good boy  :angel the  bracket and reflector stay in the down position but if you want to break the law you could leave it swiveled up out of sight all year round and pop it down for the mot
Carnt be arsed to go out and take a picture so here it is partly photoshopped you can see the bracket and butterfly nut. And the dodgy picture also shows it folded up
The reflector is like this https://www.mandp.co.uk/reflector-30x84mm-rectangular-bolt-on.html
So all you need is a strip of metal and a wing nut
Disorderlypunk
Re: Tail tidy
« Reply #15 on: 12 October 2017, 06:16:49 pm »
i think there are some anal retentive mot guys out there
on the chop i have a offside side mounted number plate and i had the reflector (the 2p sized ones shown above) on the offside of that
it couldnt be any further away from center and it still passed
-this was at a mainly car garage and i was giving one of his employees a hand getting his bikes rear wheel out so i may have got some leeway on that.
celticdog
Re: Tail tidy
« Reply #16 on: 13 October 2017, 08:12:51 am »
this is the exact route I've went down, never had a problem.
