Date: 03-04-26  Time: 22:16 pm
Author Topic: help! strange noise  (Read 7945 times)
shieldr
help! strange noise
« on: 06 March 2017, 08:15:29 pm »
Hi, riding home tonight on my 02 plate fzs600 and started to hear a strange pinking raspy kind of noise. When I open the throttle hard it sounds like a piece of tape is in the front wheel spokes/spars. Looked for something loose but there is nothing. When I got home and removed my lid I would say the engine is sounding way more clanky than normal. The oil is half way up the sight glass so ok from that point of view. Just might be an exhaust pinhole or manifold leak but also sounds like it maybe from the engine casing. I have had the bike over 3 years and it has not missed a beat. It has 26k on the clock and seems to be still pulling well. Any advice appreciated, thanks 😌
slappy
Re: help! strange noise
« Reply #1 on: 06 March 2017, 08:51:56 pm »
Cam chain maybe? Adjuster might not have clicked over to next position yet.
JoeyMcEssex
« Reply #2 on: 06 March 2017, 09:01:08 pm »
If you aint sure try putting a screwdriver handle against your ear and blade to the casing at various points to see where it is coming from?
But if in doubt get it diagnosed quick it could be terminal if not caught early!!
« Reply #3 on: 06 March 2017, 10:19:20 pm »
Cam chain sounds like a sewing machine when the tensioner hasn't quite clicked.
Depending on how you ride the bike it can take months to click to the next notch.
shieldr
« Reply #4 on: 06 March 2017, 10:27:41 pm »
Thanks guys. I have a pal at work who may be able to advise also. Hopefully it is the cam chain. Is there anything I can do to try and right it? Also will try the screwdriver tip. I will follow up on this with the answer. Cheers.
« Reply #5 on: 06 March 2017, 10:38:41 pm »
26k is okay, it's an annoying noise but not any major issue yet.
Should go away once the oil is warmed up in the engine as well.
shieldr
« Reply #6 on: 06 March 2017, 10:45:36 pm »
Thanks. Will give it a blast tomorrow. One thing though....i would say the noise was at it worst at the end of my 30 min commute...
His Dudeness
« Reply #7 on: 06 March 2017, 11:02:27 pm »
That's a bit worrying. In my experience a cam chain will be noisiest at start up and get quieter as the oil reaches operating temperature. If the engine is getting louder as the oil heats up it could be something more sinister. I'd advice not riding it until you get a mechanic to listen to it.
« Reply #8 on: 06 March 2017, 11:18:07 pm »
RPM set at right level when warm?
As the Dude has pointed out, the noise should really subside when the oil's warm.
Might be worth a second opinion, rather than finding out something nasty is wrong the hard way.
shieldr
« Reply #9 on: 06 March 2017, 11:20:27 pm »
Ok. Thanks.
« Reply #10 on: 07 March 2017, 09:20:04 am »
If the onset of the noise was sudden that does not suggest camchain to me. They tend to gradually get noisier and then go quiet again once there's enough slack in it for the adjuster to click to the next step.
It may be a blocked jet in one of the carbs causing one cylinder to run lean, hence you're getting a bit of pre-ignition when you open the throttle.
shieldr
« Reply #11 on: 07 March 2017, 08:23:46 pm »
Cheers folks. Got a right good look at it in daylight today at work. Definitely seems to be a leaky exhaust manifold. Weird noise when throttling mind. It does blow when changing up gear too soon and opening throttle.
shieldr
« Reply #12 on: 07 March 2017, 11:09:41 pm »
Got a 10mm socket then ring key on the exhaust bolts in order to nip them up...they rounded as if made of chocolate 😐
« Reply #13 on: 08 March 2017, 06:40:30 am »
If you look at the manual they're only s'posed to be torqued up very low anyway, from memory something like 10 or 12Nm.
Sounds like you could do with some new gaskets anyway as well.
Jules-C
« Reply #14 on: 08 March 2017, 07:49:28 am »
Rounding is better than shearing a stud!  Get some stainless done nuts ordered and until they arrive every time the bike is parked spray the nuts with your preferred release agent
shieldr
« Reply #15 on: 08 March 2017, 12:44:55 pm »
Will get stainless nuts. Any tips on removing the rounded ones? Ta.
JoeyMcEssex
« Reply #16 on: 08 March 2017, 06:14:32 pm »
Try to borrow a nut splitter or just hacksaw them
shieldr
« Reply #17 on: 08 March 2017, 09:37:39 pm »
Nut splitter would be good. Access is tight. Ta.
« Reply #18 on: 08 March 2017, 10:27:11 pm »
What about one of those sockets with loads of pins in, they're surprisingly good?
Jules-C
« Reply #19 on: 09 March 2017, 07:57:00 am »
Any photos of the rounded ones? A six point wall drive socket can sometimes still work if corners rounded.  But hacksaw/dremel might be best to avoid sheared studs
« Reply #20 on: 09 March 2017, 12:21:52 pm »
I have never heard of someone rounding the header stud nuts whilst doing them up ! only ever whilst trying to get seized ones off.
Sorry to ask an embarasing question but - are you turning them the wrong way?
Also has anyone else had a gasket fail ? Just wondering if a past owner has snapped a stud and refitted an exhaust but only used one side of the bracket holding the exhaust in, do you have 8 nuts
Is it an aftermarket exhaust.
« Reply #21 on: 09 March 2017, 01:50:46 pm »
The gaskets are the crush type. Overtightening the bolts a few times can flatten them out which could result in a leak.
« Reply #22 on: 09 March 2017, 02:24:17 pm »
I see, which would meant that either the headers have been off to fit new ones and the cheap skate last owner used the old gaskets or they have been off for a repair and the last owner did not know that best practice would be to replace the gaskets
daviee
  • Guest
« Reply #23 on: 09 March 2017, 06:02:50 pm »
good luck getting them off one of the not so pleasant jobs
« Reply #24 on: 09 March 2017, 06:16:37 pm »
Or like when i bought my bike and the headers were blowing, and the previous owner had put the new gaskets on top of the old ones.
