Date: 14-05-26  Time: 11:29 am
Author Topic: Front brake problem  (Read 2205 times)
phil mcglassup
Front brake problem
« on: 19 February 2017, 06:11:13 pm »
When slowing down to give way etc, I notice that my front brakes judder quite badly when the speed gets down to approximately walking speed. Any speed above this they are fine. The pads and discs look okay. I was planning on de glazing the pads.
Any thoughts anyone ?
daviee
  • Guest
Re: Front brake problem
« Reply #1 on: 19 February 2017, 06:29:19 pm »
strip and clean the pads and coppa  slip them wire wool the discs and see how  it goes from their
« Reply #2 on: 19 February 2017, 07:02:04 pm »
I had that problem years ago, virtually changed the front end of the bike before finding out it was faulty/damaged braided brake lines.
Check that the steering head stock has no play in it.
Just hold the front brake and bounce the front end, if it's loose you'll feel and hear knocking.
A siezed brake piston will push on the disc unevenly and could also cause problems.
