Date: 15-03-26  Time: 01:30 am
Author Topic: Yamaha fazer fz6 2006 - no brake light with front or rear brake  (Read 4319 times)
Ganch
« on: 18 February 2017, 12:34:27 am »
Hi all, just recently purchased my fazer fz6. Absolutely love the hike and ride compared to my previous r6!
Initially the rear light was not working all together.
I replaced the bulb and the rear light then began to work but when I pressed the rear and front brake the light didn't brighten. I have the correct bulb and I have checked the wiring to the best of my ability. Also bypassed the front switch but still the light is no brighter.
PLEASE CAN SOMEONE HELP AS I WANT TO BE OUT RIDING
Re: Yamaha fazer fz6 2006 - no brake light with front or rear brake
« Reply #1 on: 18 February 2017, 09:37:17 am »
Does the horn work? A quick look at the wiring diagram (manual in the downloads section) shows that it shares a fuse with the brake lights.
JoeyMcEssex
« Reply #2 on: 18 February 2017, 05:27:54 pm »
Are you sure it is correct bulb? is it a double element 5/21w
and have you put it in correctly-- the pins are offset and it should only be fitted one way?
JoeyMcEssex
« Reply #3 on: 19 February 2017, 08:30:26 pm »
Got it fixed yet?
BBROWN1664
« Reply #4 on: 28 February 2017, 06:14:23 pm »
Get someone with a multi-meter to check the wiring
One pin on the rear light holder will be +12v with the lights on, the other when you put the brakes on.
The outer part of the buld holder should be directly connected ot earth.
If any of the 3 things above are not correct (with no bulbs fitted) then you have a wiring issue. the exception to this is if you don't get 12v on the brake light pin. You could just be unlucky and have two (front and back) failed switches.
