Date: 29-03-26  Time: 18:25 pm
Author Topic: Optimate Battery Charger Question  (Read 2911 times)
YamFazFan
« on: 11 February 2017, 07:27:24 pm »
Would a 12 volt Optimate motorcycle battery charger be suitable for charging a car battery?
Many thanks YFF
Re: Optimate Battery Charger Question
« Reply #1 on: 11 February 2017, 07:46:45 pm »
Dont know but I have a YAM branded one that can also do cars but there is a switch to turn it to car mode but I dont know what the difference is
EDIT after Jos post to be clear mine is not an optimate with yam branding but a CTEK with yam branding
joebloggs
« Reply #2 on: 11 February 2017, 08:26:33 pm »
My optimate has a setting for car batteries
fatbloke62
« Reply #3 on: 11 February 2017, 09:09:00 pm »
i've used mine for years on the car as well as the bike
Frosties
« Reply #4 on: 11 February 2017, 10:24:18 pm »
If it's say an Optimate 3 without a car function mode then it will be fine but will take days to charge say a 60AH car battery. Outputs for bike batteries are lower. So yup will be fine but may take a lot longer than a dedicated car charger or bike charger with switchable output.
« Reply #5 on: 11 February 2017, 10:46:47 pm »
In the real world a battery is a battery.
A bike charger will most certainly charge a car battery, but the ampage on a car battery will obviously be higher so will just take longer.
My "battery man" at work goes by the rule that chargers should pump out a quarter of a batteries ampage.
Ie: a 12amp battery should have a 3amp charger, or less, to avoid overcharging or frying it.
But a bike charger falls well within those limits.
As long as it has a trickle charge mode it'll be fine.
« Reply #6 on: 11 February 2017, 10:49:18 pm »
If i remember correctly a trickle charge bounces around the 10% charging mark once a full charge is near.
YamFazFan
« Reply #7 on: 12 February 2017, 07:32:07 pm »
The charger is an Optimate 3 without the switch for car batteries. Sounds like it will be OK, but just take a long time.
Ta for replies :)
« Reply #8 on: 12 February 2017, 07:42:38 pm »
The website says it has a 0.8 amp output, which is very low.
tommyardin
« Reply #9 on: 12 February 2017, 11:36:00 pm »
My battery conditioner put out less than 1amp, it an Oxford unit
ProdigalSon
« Reply #10 on: 28 February 2017, 07:28:07 pm »
No good if I wanted a quick start but I use my Optimate 3 to keep the battery on my car topped up and that's a 95Ah . :)
