Date: 29-03-26  Time: 12:45 pm
Author Topic: Changing the bar's  (Read 1566 times)
Rabbit22
Changing the bar's
« on: 06 February 2017, 08:01:06 pm »
Hi all.
Well I'm looking at changing the bar's on my fz6 05 plate to a set of ultra low renthal's,  but remember reading somewhere that I would need some slight modifications. Do any fz1 bars fit as they look like they are flat bars?
Graham53
Re: Changing the bar's
« Reply #1 on: 06 February 2017, 08:31:52 pm »
When I changed the bars on my foxeye to renthals I had to drill small holes in the bars for the switches and levers as they have locating pins on them, I assume that FZ6 is the same , I do know some just file off the pins in the handle bar switches and levers which is a bit irreversible and depending on how the FZ6 bar end weights mount you may need to get renthals ones or find a way to fit the oe ones.
I'm not sure about the fz1 bars as again the locating pins might be in a different position and you're back to the drill holes or file pins conundrum.
Rabbit22
« Reply #2 on: 07 February 2017, 07:18:10 pm »
Cheers Graham53, what renthals did you go for?  I was looking at ultra lows unless their is a set which are even flatter
