Date: 04-11-25  Time: 19:12 pm
Author Topic: Carb Idle adjuster difficulty  (Read 2838 times)
Graham53
« on: 28 January 2017, 04:36:03 pm »
i thought I'd have a go at Ivan's TPS adjustment today
However I can't get the idle screw adjuster to set the idle above 1800 rpm  :'( no matter how much I turn it
It will allow me to return back to normal idle speed but when blipping the throttle after the revs sort of hang around a bit at 4000 and drop back slowly.
Anyone got a clue why I can't get the idle above 1800.
darrenc
Re: Carb Idle adjuster difficulty
« Reply #1 on: 28 January 2017, 07:13:39 pm »
Why you trying to idle it above 1800? I'm only asking because today I was trying to get my pissing TPS sorted so increased my idle from around 1000 to the recommended 1250-1350 (again I found the screw difficult to turn by hand) in the end I couldn't get the TPS to read anything but 10000
 So far I have had new plugs, carbs cleaned and balanced as well, I did briefly see the correct 5000 reading but it then shot up to 10000 so I just moved it back to the position it was in and tightened screws, bike seems to run OK so fuck it.
Graham53
« Reply #2 on: 28 January 2017, 08:03:26 pm »
The Ivans method of setting the TPS requires setting the idle to 3800 rpm before adjusting the TPS
http://www.cartestsoftware.com/fz1/throttlepositionsensoradjustment.html
Check this link and scroll down to the addendum
darrenc
« Reply #3 on: 28 January 2017, 08:05:13 pm »
BRI I will try mine again tomorrow using this info :)
darrenc
« Reply #4 on: 28 January 2017, 08:06:02 pm »
*brill I've supped a few ales and struggling to type, maybe I shouldn't try this tomorrow ;)
darrenc
« Reply #5 on: 28 January 2017, 08:10:15 pm »
Mmmmm it only suggests that method for re-jetted bikes and not stock setup. Unfortunately I don't what mine is because the fuckwit who owned it before me only rode it 4 times in two years and two of those times it ended up on the deck.
darrenc
« Reply #6 on: 28 January 2017, 08:10:55 pm »
So I doubt he knows which way is up never mind the setup of the bike
Graham53
« Reply #7 on: 28 January 2017, 08:11:48 pm »
Hope you have better luck than me  :'(
darrenc
« Reply #8 on: 28 January 2017, 08:16:01 pm »
Me too, I'm all for kicking the bike in its nuts, I should have bought another hornet, that little pocket rocket never let me down.
Graham53
« Reply #9 on: 28 January 2017, 08:22:59 pm »
im sooo frustrated with mine at the moment maybe I should've got one of them too  :'(
darrenc
« Reply #10 on: 28 January 2017, 08:25:39 pm »
Maybe we can trade both our bikes in and get one good bike, im a weekly commuter but its all your at weekend  haha :)
Graham53
« Reply #11 on: 28 January 2017, 08:31:43 pm »
That sounds like a plan , I was 5 minutes from pouring petrol over it today and claiming the insurance
darrenc
« Reply #12 on: 28 January 2017, 08:32:26 pm »
Haha shit just realised this is for the FZ1 I don't even have that bike, I'm off to bed :)
Graham53
« Reply #13 on: 28 January 2017, 08:35:02 pm »
You know the FZ1 is American for fazer 1000
darrenc
« Reply #14 on: 28 January 2017, 09:04:27 pm »
I don't have a Fazer 1000 either ;)
Graham53
« Reply #15 on: 28 January 2017, 09:27:58 pm »
Sorry bud thought you did as is the 1000 forum.
600 TPS should be easy enough to set up , do the check , disconnect TPS turn on ignition ,code will read 0k 5k or  10 k undo TPS move until it reads 5k , tighten it up unless that's what you've been doing then I'm stumped or post thread in 600 section
darrenc
« Reply #16 on: 28 January 2017, 09:49:28 pm »
Told you I was pissed haha, yeah tried all the usual, ignition on, remove TPS connector and connect it back up, it reads 10000, I then undo bolts swivel it about a bit and it doesn't budge for shit, tightened it back up and left it, swore at it a few times then went in house to drink ale.
Graham53
« Reply #17 on: 28 January 2017, 09:54:43 pm »
Sorry mate can't do anymore than say enjoy the ale or put post in 600 section or search TPS probs
