Date: 27-03-26  Time: 16:59 pm
Author Topic: fork seal leak  (Read 3854 times)
sc0ttie
fork seal leak
« on: 11 January 2017, 01:55:24 pm »
My right hand fork seal is leaking, noticed it this morning upon arrival to work. I can't get it replaced until Saturday, is it ok to ride to work still? It's 10 miles trip each way.
Re: fork seal leak
« Reply #1 on: 11 January 2017, 02:01:12 pm »
As long as it's a thin coat on leg & not pi**ing out you should be ok.
If it snows Thursday evening have a snow day Friday.Smile
Re: fork seal leak
« Reply #2 on: 11 January 2017, 02:15:39 pm »
Yeah, been watching the weather forecasts all day, it's not looking good tomorrow as far as snow's concerned.
I'm gonna get a workmate to pick me up in the morning, as I really don't want my bike stranded at work. They're hinting it could start late afternoon "if" it happens, but then again over night.
TOADY
Re: fork seal leak
« Reply #3 on: 11 January 2017, 03:49:43 pm »
wheres the link for that fork seal tool thingy, i'm sure somebody can link you to that and you can get it sorted
Re: fork seal leak
« Reply #4 on: 11 January 2017, 04:00:31 pm »
http://foc-u.co.uk/index.php/topic,21475.msg246644.html#msg246644
Bretty
Re: fork seal leak
« Reply #5 on: 11 January 2017, 05:31:47 pm »
My forks had a slight leak when I got them and I did about 10k miles on them no problem. Only changed them this some during a full service. I made a dodgy fork seal tool with two pieces of split  plastic pipe one inside the other with a bike jubilee clip around the lot. It worked a treat.
Re: fork seal leak
« Reply #6 on: 11 January 2017, 05:40:52 pm »
prise up the dust seal and cut a strip of cloth about a inch wide by about 4 inches long cover it in grease and pack it into the fork where the seal is push the dust seal back down and wipe any excess grease away pump the forks a few times and clean any grease that shows on the leg then your good to go i have done this many times and it works a treat , i have  had years out of forks with this done and no more leaks . i do this now to every bike as the light smear of grease that is wiped on with the cloth lubes the seal  , since i have  started doing this i have never had a fork seal go , been doing it for about 30 years red rubber grease is about the best for it , it is worth a try so get  you by till you get a chance to replace them
sc0ttie
Re: fork seal leak
« Reply #7 on: 11 January 2017, 07:40:43 pm »
Thanks all, i will make my own seal cleaner tool with a bit of old plastic transparency sheet I have and if i am not able to stop the leakage after that I will see about getting seals replaced. Garage wants £170 to do the pair.
Re: fork seal leak
« Reply #8 on: 11 January 2017, 08:53:02 pm »
If you've never done fork seals before this link will help,if you have the tools/Haynes manual for torque settings,10w fork oil is std grade & oil level from top of fork tube to oil is 121mm.
mtread
Re: fork seal leak
« Reply #9 on: 11 January 2017, 09:22:57 pm »
How much!  :eek  You might want to shop around
Re: fork seal leak
« Reply #10 on: 12 January 2017, 08:42:08 am »
its only a 2 hour job from riding into your garage to riding away again. Not difficult to do either. Be brave and have a go yourself. The worst that will happen is you have the legs off the bike and don't have to pay the workshop for half the labour.
mtread
Re: fork seal leak
« Reply #11 on: 12 January 2017, 09:32:17 am »
Especially this time of year. Bike shops have mechanics twiddling their thumbs and should grab work with a discount
sc0ttie
Re: fork seal leak
« Reply #12 on: 12 January 2017, 12:02:37 pm »
Is a leaking fork seal an MOT fail.
Re: fork seal leak
« Reply #13 on: 12 January 2017, 12:32:09 pm »
Yes it is a fail, because if it's low on oil it will affect safety and handling.
When you replace the oil use 15w instead of 10w, it improves handling quite a bit.  :thumbup
Re: fork seal leak
« Reply #14 on: 14 January 2017, 12:55:03 pm »
print off A4 and cut a thin plastic milk bottle to shape
