Date: 12-05-26  Time: 09:35 am
Author Topic: 16 t Front Sprocket  (Read 3550 times)
Carlsv8
16 t Front Sprocket
« on: 24 December 2016, 03:58:25 pm »
I'm going to change my front sprocket for a 16t one. Any makes recommended or any bad experiences with certain types. I've read that if the sprocket is harder than the shaft it will wear the shaft and would rather this didn't happen (obviously ).
Happy Xmas
Cheers
Carl
daviee
  • Guest
Re: 16 t Front Sprocket
« Reply #1 on: 24 December 2016, 06:51:27 pm »
herd they dont respond well to a bigger sprocket
Carlsv8
« Reply #2 on: 25 December 2016, 03:27:33 pm »
I'm used to bigger engined bikes which are less revvy. Don't spend a lot of time in traffic so I reckon slightly higher gearing will be an improvement, I think the bike has enough poke to handle it.
daviee
  • Guest
« Reply #3 on: 25 December 2016, 03:46:35 pm »
from what i herd it spoils them , bus not a dear thing to try it
phil mcglassup
« Reply #4 on: 26 December 2016, 04:44:09 pm »
I went up one tooth on the front sprocket on my previous bike (GSX750f) as I used it for longer journeys. I did stall it occasionally, even one up and it became a nuisance. It was marginally better on long journeys as it was running lower revs and economy was slightly better. I eventually changed it back to standard as most modern bikes are designed to rev high. I always kept to the speed limit which helped !!
My Fazer seems to enjoy revving it's bollocks off at motorway speeds  :)
tommyardin
« Reply #5 on: 26 December 2016, 06:48:07 pm »
Hi Guys,
It may or may not be something to consider when going up a sprocket size, is that the clutch push rod emerges from the engine just in front of the sprocket check that there is enough clearance to accommodate a larger sprocket and if there was any chain slap that the push rod would not be damaged.
I'm not sure how close it is as I do not really remember, but I have heard that if the sprocket comes off (Faulty Sprocket Nut) it often screws the clutch push/activation rod.
Just a thought.
Hope you all had a great day yesterday.
I have my bottle of Southern Comfort close to hand. :rolleyes
daviee
  • Guest
« Reply #6 on: 26 December 2016, 07:10:11 pm »
6 grand a 75 is hardly reving the bollocks of it
Frosties
« Reply #7 on: 26 December 2016, 08:13:37 pm »
You're not trying hard enough  :lol
