Date: 18-07-26  Time: 00:42 am
Author Topic: LED replacement bulbs for FZS1000  (Read 62391 times)
tommyardin
Re: LED replacement bulbs for FZS1000
« Reply #25 on: 22 December 2016, 09:24:26 pm »
Well took to mot yes it pass with flying colour mot inspector said how bright the both lights were
Fu@k me I going to get set  :eek  went I left it was dark and my god beam is spot on I have hid for years but theses beat them with hands down  :lol
Well done Topgun, a result.
If you have a link to the site you purchased them from any chance you can post in in here? If they are that bright that maybe the way I will go. :guitar
topgun44
« Reply #26 on: 23 December 2016, 12:26:48 am »
https://www.amazon.co.uk/Safego-Headlight-Conversion-Warranty-PHL6E-H4/dp/B01H59HZ5G/ref=sr_1_8?ie=UTF8&qid=1481323049&sr=8-8&keywords=H4+hi%2Flo+LED
Look like they are sold out maybe new stock in new year or you can get them on eBay for 80 which is 20 pound more I pay for them good luck
old son
« Reply #28 on: 28 December 2016, 09:52:53 am »
What way are you guys turning these bulbs to ensure they get as close to the original beam pattern as possible? Mine are currently installed as they were delivered. Will I be far out?
topgun44
« Reply #29 on: 28 December 2016, 02:08:30 pm »
just installed them same as you plug a play took it to the mot and pass  ;)
old son
« Reply #30 on: 28 December 2016, 04:37:55 pm »
Brilliant, thanks for the update
topgun44
« Reply #31 on: 12 January 2017, 07:11:28 pm »
they are back in stock people
old son
« Reply #32 on: 13 January 2017, 08:10:47 am »
I have installed mine and took the bike to have the beam angle checked. The near side was spot on and the offside was at the top of the range for height and needed adjusting to face the nearside a bit more. Now spot on and very happy with them.
b1k3rdude
« Reply #33 on: 15 January 2017, 09:02:52 pm »
Good to see these replacement bulbs are working out, how did you adjust it btw - just turned it around untill it was compliant ..?
ogri48
« Reply #34 on: 20 January 2017, 06:08:32 pm »
Ordered mine today, cheers mate.... :)
old son
« Reply #35 on: 21 January 2017, 10:45:04 am »
I had the headlight unit adjusted using one of the gadgets they use when they do the MOT. I removed the inner panels to give access to the adjusters and he adjusted them for £0!!  Took him about 20 seconds. Only one needed adjusting, the other was spot on out of the box.
ogri48
« Reply #36 on: 22 January 2017, 04:38:40 pm »
Yup they rock. Bulb on the left is a 20 w 4000 lumen LED, bulb on the right is an expensive halogen night breaker, which is supposed to be 140 percent better than a normal halogen h4
Dudeofrude
« Reply #37 on: 22 January 2017, 07:20:58 pm »
Would ones of this fit in the Fz1 too? It still uses a H4 bulb (I think) and I've got the naked model so would only need one 😋😋
old son
« Reply #38 on: 23 January 2017, 01:15:20 pm »
The Gen 1 is H4 dual filament. The kit comes with two bulbs
ogri48
« Reply #39 on: 23 January 2017, 07:25:22 pm »
These are bloody brilliant. I can even see well coming home tonight with my shoei neotec flip front up and the sun visor down. It's the white light, it's just a different league. It was actually a bit disconcerting on bends til I got used to it as it was very very cold and the roads look white with frost!
topgun44
« Reply #40 on: 23 January 2017, 09:36:40 pm »
know you need to  loose them yuck! side light bulb for led then you look the part  ;) oh i might see you riding around Norfolk know  :lol
JonnyFoxtrot
« Reply #41 on: 16 February 2018, 04:31:52 pm »
Sorry to revive an old topic but I was after replies specifically from those who have done the upgrades!
I've got the oppertunity to get these bulbs (the ones linked from Amazon with no fan) for under £30, is everyone still happy with them? Had any issues at all?
old son
« Reply #42 on: 16 February 2018, 05:10:48 pm »
Mine have been brilliant. No breakdowns and absolutely no issues.
JonnyFoxtrot
« Reply #43 on: 16 February 2018, 05:12:06 pm »
Brilliant cheers!
b1k3rdude
« Reply #44 on: 18 February 2018, 09:47:14 pm »
Mine are still going strong, so I'm trying to get a set of H7 for my bandit.
stet
« Reply #45 on: 18 February 2018, 11:03:25 pm »
b1k3rdude
« Reply #46 on: 21 February 2018, 05:47:24 pm »
The issue was getting the rear of the bulbs to seal against the OEM seal -
But now thinking about it I think I will have to make up some rubber gromets/seals to seal the gap instead. As you can see from the image above thats the stock bulb and the connector/spacer that plug into and converts the H7 to H4 spacing. The back of the LED bulbs needs to be roughly the same length and I will make a space for the width.
Ripsnortingvtwin
« Reply #47 on: 13 February 2019, 01:12:47 pm »
what ones did you get ????
ogri48
« Reply #49 on: 13 February 2019, 04:26:04 pm »
ayuh mine still going strong. worth every penny and then some, wish id  used them instead of the cheaper ones in my other two bikes and van.
