Date: 30-04-26  Time: 11:35 am
Author Topic: Gen 2 adjustable dogbone  (Read 2725 times)
Rob R
« on: 16 November 2016, 10:05:36 pm »
After fitting an R1 shock I had to lower the ride height (R1  shock is about 1" longer than the FZ1 shock). I checked fleabay and decided I could make an adjustable linkage myself so I bought  a right & left handed M12 rod end bearing and a length of 19mm stainless hex and this is the result. Total cost £12.50!
devilsyam
Re: Gen 2 adjustable dogbone
« Reply #1 on: 16 November 2016, 11:00:57 pm »
Tip
Do a trial fit to set length
Undo one end making sure other is fully tight
Note position of lock nut
Get some larger heat shrink and to to length to cover the nuts refit the end and tighten pull know the heat shrink to do this then making sure nuts are covered shrink down
This will ensure all stays together
Andy W
« Reply #2 on: 17 November 2016, 07:09:09 pm »
Looks jolly ingenious & cost efficient to boot!  :D  Nice one!
This Devilsyam fellow has some experience in these matters I believe,
so may be worth heeding!  ;)
Rob R
« Reply #3 on: 17 November 2016, 08:39:25 pm »
Thanks for the advice Devilsyam.
I chose to use a right hand and left hand thread so I could adjust it without having to remove the linkage, I'd not given any thought to protecting the threads...
Rob
Bubbaad
« Reply #4 on: 19 November 2016, 10:40:56 am »
Great idea......You got the item number for the hex bar.........Ta
devilsyam
« Reply #5 on: 19 November 2016, 02:45:24 pm »
yep rob it will protect the threads but more over its to lock the nuts just in case they work loose
Rob R
« Reply #6 on: 20 November 2016, 08:35:02 pm »
No number/grade for the hex bar, just a nice free cutting s/s.
