Date: 08-05-26  Time: 04:49 am
Author Topic: New inlet rubber for the carburetors  (Read 19777 times)
celticdog
Re: New inlet rubber for the carburetors
« Reply #50 on: 23 April 2018, 10:42:05 am »
Got my Chinese inlet rubbers in less than 20 days, and I have changed them over the weekend. It took some skill tko get all four rubbers at the same time in the carb, but I did it. the engine is running, now I just have to drive it to see if the problem with decrease of rpm in quick throttle open is still happening.
Good to hear that they're of usable quality, I ordered a set at the weekend. Gives me enough time to overhaul the carbs before they arrive.
Roky
« Reply #51 on: 23 April 2018, 10:52:03 am »
Quality is ok, the only problem with mine was that the brass tubes are not shaped right, and they tend to much towards engine. But I is possible to point them to another direction :)
redmandan
« Reply #52 on: 23 April 2018, 03:14:32 pm »
After superglueing the brass post back in they're working great. As I rev the engine I can see them changing shape slightly as the pistons suck from the carbs so they must have great fitting.
celticdog
« Reply #53 on: 23 April 2018, 05:09:12 pm »
That's a good point, how did you blank off the vac ports- do they come supplied with blanking caps?
redmandan
« Reply #54 on: 23 April 2018, 06:27:38 pm »
I just used the old ones that were on my original Yamaha rubbers. They're still in good nick.
I toyed with the idea of throwing away the little metal clips that hold them on as they are so bent now its almost impossible to open them.
