Date: 08-05-26  Time: 04:48 am
Author Topic: New inlet rubber for the carburetors  (Read 19771 times)
Bimbam
« on: 09 November 2016, 07:10:18 pm »
Hi
Does anybody know an internet shop where I can buy the four inlet rubber for the carburetors?(Position 1 +2)
The original spare part is way too expensive.
Pandy
Re: New inlet rubber for the carburetors
« Reply #1 on: 09 November 2016, 08:43:35 pm »
Hi!
I just had the same problem on my FZS600. I bought them from ebay, there are plenty sellers with different prices. I paid for all 4, 90.50€ including postage from Germany to Romania (10€).
I think it's a good price 20€ per one brand new inlet.
Hope i helped,
Iulian
« Reply #2 on: 09 November 2016, 10:44:21 pm »
 WeMoto or M&P have them
Dave48
« Reply #4 on: 10 November 2016, 08:46:54 am »
I think M&P Direct are cheaper than the above.
« Reply #5 on: 10 November 2016, 11:07:01 am »
They're a £8 more expensive than the top link (incl. del.). I'd already checked them.
http://www.mandp.co.uk/index.php/default/motorcycle-spares/spares/engine-parts/229845-carb-to-head-rubbers.html
Pandy
« Reply #6 on: 10 November 2016, 02:59:46 pm »
Bimbam
« Reply #7 on: 10 November 2016, 03:06:51 pm »
Thx for the help  :lol
« Reply #8 on: 10 November 2016, 03:46:06 pm »
Onevan
« Reply #9 on: 27 December 2016, 08:21:11 pm »
It may be worth checking the rubbers as they could be split only on the "outside". I removed mine and checked them with a dye penetrant and used developer on the inside. No sign of leakage so just filled the "outer cracks with clear silicon sealant and a bit of black marker pen to colour them in. £80 is still in the bank 😃
rw711
« Reply #10 on: 27 December 2016, 10:55:37 pm »
http://www.thejunkmanadv.com/cracked-rubber-intake-boot-fix.html
Just one of a few links I've seen where they replace with silicon hose ? looks cheap and durable if not for concours restoration jobs - not sure skill level though?
a few youtube vids showing similar?
daviee
  • Guest
« Reply #11 on: 28 December 2016, 01:16:07 pm »
£70-80 is  not expensive for what you are getting most other  bikes are the same
Roky
« Reply #12 on: 30 March 2018, 04:00:54 pm »
Hello
I alo have question about these rubbers. I just baught fazer 1000 year 2003 and I noticed some reather big cracks on my inlet rubbers.
When I drove it home I noticed taht as well as in low and high rps, when I open throttle quick, the engine stays on the same rpm for a second or two and then it starts to accelerate. Or when the engine is cold or when the bike is not moving, and I open the throttle quick the rpm fall pretty much and the it starts to accelerate, or ita also hapens, that the engine dies. Is that the problem beacuse of these cracks on rubbers?
Regars
adasilva
« Reply #13 on: 30 March 2018, 05:01:20 pm »
Hey.[/color]I bought new rubbers for my Fazer 600 2002 a few weeks ago. They cost me 79 pounds + shipping. i got them from yambits https://yambits.co.uk/fzs600-fazer-carb-inlet-rubbers-p-75890.html?osCsid=i0v9ick2tlmsp3kmd5grgmru74[/size]
[/color]The ones that were in the bike had some small cracks on them. After removing them i noticed that one was a bit bad but the other ones apart from having hairline cracks on them, it did not go thru the rubbers.[/size]
[/color]So if i were you i would take them apart first and check. Sometimes the cracks are just superficial and it has not gone thru. Also those rubbers have a hard core inside of them so you might be fine. [/size]
i have 3 of them if you interested.
Good luck.
Roky
« Reply #14 on: 30 March 2018, 05:32:27 pm »
Hey.I bought new rubbers for my Fazer 600 2002 a few weeks ago. They cost me 79 pounds + shipping. i got them from yambits https://yambits.co.uk/fzs600-fazer-carb-inlet-rubbers-p-75890.html?osCsid=i0v9ick2tlmsp3kmd5grgmru74
Good luck.
I will try to take them off to see how they look, although I can see a little bit of metal trough one, right on the joint of sharp metal and rubber.
Can these rubbers be the cause, of my acceleration problems?
adasilva
« Reply #15 on: 30 March 2018, 06:11:04 pm »
Hey Roky
if you are seen the metal trough one then is bad. And yes you will might have some issues with your bike's performance if there is too much air going in.
But i also would check for other things after you replace those. like spark plugs, air filter.
good luck
Roky
« Reply #16 on: 30 March 2018, 07:06:18 pm »
Hey Roky
good luck
Well then I have to change those f.... rubbers :)
I hope that it is just this problem, othervise I will have to go to some mechanic to make my Fazer run again
« Reply #17 on: 30 March 2018, 11:49:35 pm »
Hey Roky
good luck
Any unwanted extra air at all will cause big problems, mainly bogging down on acceleration.
redmandan
« Reply #18 on: 31 March 2018, 12:13:17 pm »
I'm also in the market for some new inlet rubbers. I found some real cheap ones from China on eBay for £15 delivered. I looked again recently and they've gone up to £20. They haven't arrived yet and I'm fully prepared for them to be junk but hey, maybe I'll get lucky.
Roky
« Reply #19 on: 31 March 2018, 03:22:12 pm »
i think I will also buy something from Cihna. If you get them before I do please report here if they are ok.
His Dudeness
« Reply #20 on: 31 March 2018, 03:48:02 pm »
Yeah report back when you fit them ;) There seems to be a lot of sets on ebay for under £20. Most likely they are all from the same manufacturer. It'll be interesting to see the quality of them compared to the Yamaha ones.
hopefiendboy
« Reply #21 on: 31 March 2018, 07:07:43 pm »
His Dudeness
« Reply #24 on: 31 March 2018, 08:57:52 pm »
Its a shame you can not just buy the outer two because I am pretty sure that it is UV damage that makes them go hard and crack and the inside ones are sheltered
