Date: 30-04-26  Time: 18:54 pm
Author Topic: Am I being a Numptie  (Read 4271 times)
Timbo
« on: 07 November 2016, 10:53:35 am »
Hi all
Am I imagining it or should the tacho flick to the red line when you first switch the ignition on???
I had a 7K rpm fault show up on Friday (just once), the EXUP is all lubed and checked but I am starting to think I have a duff servo motor. Before I go charging off now that route I would like  a reality check.
The bike actually runs alright but I do get a crackling noise from the servo and it does'nt seem to move  at all when I switch the ignition on.
Or am I just getting old and confused :\ !!?
Timbo
Re: Am I being a Numptie
« Reply #1 on: 07 November 2016, 12:11:38 pm »
Sorry (numptie me) I'm talking about a Gen 1
Bw
robbo
« Reply #2 on: 07 November 2016, 01:03:23 pm »
Hi Timbo,
The tacho shouldn't move when you switch on the ignition. If you do a Search on "crackling noise" the first hit you should get is dated 23 Feb 2016. There's a good explanation and servo test info posted there by Windscreenman.
Hope this helps and allays any fears.
Good luck.
robbo
Tmation
« Reply #3 on: 07 November 2016, 01:46:01 pm »
Timbo
« Reply #4 on: 07 November 2016, 01:59:18 pm »
Thanks for the replies.
I need to spend a bit more time on it next weekend but I do think the servo is duff. No reaction at all when the ignition is turned on.
Bw
robbo
« Reply #5 on: 08 November 2016, 12:31:25 pm »
I presume you meant to post your last question under this heading :lol .
Regarding the servo, you only hear it operate when you switch on the ignition after the bikes been running. Then if you switched the ignition off without starting and then on, it wouldn't operate.
Timbo
« Reply #6 on: 08 November 2016, 03:12:36 pm »
Ahh...I did wonder whether I was missing something. Am I right in thinking that the kill switch has a part to play in this too?
Thanks for replying too
Bw
robbo
« Reply #7 on: 08 November 2016, 05:33:26 pm »
I hardly ever use the kill switch but would imagine the same scenario as with the ignition.The servo will "cycle" the first time the ignition is turned on after the engine has been running.I can do a comparison of stopping the engine with the key and then the kill switch tomorrow,but no doubt someone will have the answer for you before then.
Timbo
« Reply #8 on: 08 November 2016, 08:32:15 pm »
I can't either...not home!!
Bw
robbo
« Reply #9 on: 09 November 2016, 12:40:58 pm »
If you turn off the engine via the kill switch you hear the servo cycle to it's"home"position.If you turn it off via the key it returns to "home" when the ignition is next turned on.Hope that makes sense.
Timbo
« Reply #10 on: 09 November 2016, 02:11:20 pm »
Thanks Robbo,
I'll be home tomorrow, I'll check it out. I think I overlooked the fact that nothing will happen unless I start the engine. I an all other respects it seems to run fine!
I was'nt having a very good weekend.....wound up and not thinking straight!! :rolleyes
Bw
robbo
« Reply #11 on: 09 November 2016, 03:03:23 pm »
I think it's just one of those things that one gives little thought to until the question's asked. Once the servo has "homed", it won't matter how many times you turn the ignition on/off without starting the engine, it won't "home" again until the engine has run.
Good luck, hopefully you've been concerned about nothing. :thumbup
Timbo
« Reply #12 on: 11 November 2016, 09:12:32 am »
Yes ...I am a numptie
Switched engine ON :o ! ........and noted that the servo moved! Hooray!
Taken the opportunity tho to grease and lube, cables as well.
Doh
