Date: 01-05-26  Time: 07:06 am
Author Topic: Lcd display gorn  (Read 3386 times)
The Yooge
Lcd display gorn
« on: 30 October 2016, 07:49:11 pm »
Hi, I bought my 2002 FZS 1 a couple months ago, the lcd screen on instrument cluster was blank (service and mot history told me the mileage) anyone any ideas if this can be fixed or is it going to be a whole new unit? Enjoying this excellent dry year on the roads!
tommyardin
Re: Lcd display gorn
« Reply #1 on: 30 October 2016, 10:41:03 pm »
Don't have one of those (FZS600 here) but have you checked that there is power to the LCD unit for starters?
Must have a multi pin plug that goes in the bottom of the beastie somewhere, stick a multi meter on it. Does it illuminate when the lights are on, if not might just have come unplugged. Worth a look.  :rolleyes
The Yooge
« Reply #2 on: 31 October 2016, 09:02:31 pm »
Thanks Tommy, dash lights are on, everything else works fine, I'm no sparky but I may have to open it up to see if there's anything amiss.
« Reply #3 on: 31 October 2016, 10:59:54 pm »
Check the backup fuse
tommyardin
« Reply #4 on: 01 November 2016, 10:13:39 am »
Sounds like a sensible move  :think
The Yooge
« Reply #5 on: 02 November 2016, 06:24:06 am »
Cheers, will do, my birthday yesterday, Scottoiler and Haynes manual on their way!
The Yooge
« Reply #6 on: 02 November 2016, 09:08:37 am »
Not fuses, they're all ok, had thought it may be the ignition barrel but all other parts of clocks work fine. Any other ideas?
« Reply #7 on: 02 November 2016, 06:56:39 pm »
Take off the screen an unplug the connector to the clocks and check for 12 volts on two wires
The red/green which should have 12 volts all the time (fed from the Backup fuse) and keeps the clock time and trip meters from resetting
The brown which should only have 12 volts with the ignition switched on.
If there is power on both of these then it is an internal issue in the clocks which could even be something as simple as a dry solder joint.
If you are brave enough to take the clocks apart I could tell you what to check before you consign then to the bin.
The Yooge
« Reply #8 on: 02 November 2016, 10:36:54 pm »
Thanks unfazed, I will have a butchers asap
