Date: 25-05-26  Time: 08:36 am
Author Topic: Removing cylinder head cover  (Read 9322 times)
mark747eagle
« on: 14 March 2012, 11:22:08 am »
I still have AIS fitted, but I need to remove the cylinder head (valve) cover to rub down and paint it.  Does anyone know if I have to remove the AIS / radiator etc to do that?  Or willl the cover come out without disturbing AIS?
sadlonelygit
Re: Removing cylinder head cover
« Reply #1 on: 14 March 2012, 11:35:09 am »
Hahahahahahahahahahaahahahahahahahahahahahahahahahahahahahahahaha.................plonk.
mark747eagle
« Reply #2 on: 14 March 2012, 11:37:43 am »
is that a 'no' then?
sadlonelygit
« Reply #3 on: 14 March 2012, 11:50:08 am »
apart from check tyre pressures, adjusting the chain.........ais is in the way is in the way of everything!
mark747eagle
« Reply #4 on: 14 March 2012, 11:57:32 am »
oh well better roll my sleeves up and dig out an 8mm tap then.  Ta
GrahamB
« Reply #5 on: 14 March 2012, 12:43:36 pm »
Good luck with that. Make sure it's a good quality tap & I hope you got a spanner or something small enough to fit the end. You can hardly get on it for cylinders 1 & 4.  Not the nicest job I got to say.  :(
mark747eagle
« Reply #6 on: 14 March 2012, 01:06:07 pm »
I thought it might be.  Borrowed a set of Clarke taps from a mate.  I think I have BA spanners that will fit.  I was hoping I could get the cover off without all this but.....
GrahamB
« Reply #7 on: 14 March 2012, 01:45:40 pm »
You could always refit all the pipes once the cover is painted? You don't HAVE to ditch the AIS when you take it all off but I know where you're coming from in wanting to.
mark747eagle
« Reply #8 on: 14 March 2012, 01:57:25 pm »
That'll still mean removing the tank and draining ad removing the radiator?  I cant see how else to get the pipes off.  The manual was a bit confusing.  Suggested removing AIS pipes for better access to valve shims - which I thought meant you could get the cover off without taking the AIS pipes out - but I can't see how!
eddie
« Reply #9 on: 14 March 2012, 04:59:27 pm »
mark747eagle
« Reply #10 on: 14 March 2012, 05:38:13 pm »
Thanks.  That's brilliant!  :)
Falcon 269
« Reply #11 on: 14 March 2012, 06:47:01 pm »
This is the tap you need.  Please don't try the job with anything other than a tapered tap or you'll likely be back here asking how to remove a broken one from the stub. :(
VNA - BMW Wank
« Reply #12 on: 14 March 2012, 07:07:28 pm »
Quote
Ach it's not that difficult, not that difficult at all.
Yes you need to get the radiator out of the way.  Can't remember what I used on the end of the tap, either a small spanner (ring spanners are always nice if you can get em on) or a 4 inch shifter.
I might be trying to tell you how to suck eggs, but just in case.  As Mike says, start with the taper tap, make sure you get it in square, and once you have it established - turn it in a half or full turn at a time, then back it off and in again, work in gradually, bring it right back out now and again and clean all the crap off the tap.
1 and 4 are tight but it'll go.
Use a good quality tap.
These should be OK;
www.buckandhickman.com/find/keyword-is-m8+tap+taper/product-is-022624
Has the bike been Ivanised?
mark747eagle
« Reply #13 on: 14 March 2012, 08:21:06 pm »
Tanks guys - no the bike hasn't been Ivanised unfortunately.  I have borrowed a decent set of tapered taps, have used them before but a long time ago.  (as a hint - it was a BSA Starfire....)  :)
VNA - BMW Wank
« Reply #14 on: 15 March 2012, 06:09:04 pm »
Well worth getting it Ivanised (if a former owner hasn't done it already)
It'll pull strong and clean from 2000rpm and is much much smoother once Ivanised, it rids the bike of surging at steady lower rpm running.
Mike (Falcon269) did mine along with 100's of others.
mark747eagle
« Reply #15 on: 15 March 2012, 06:20:55 pm »
Thanks for that - will look into Ivanising.  The tapping is noty proviing very sucessful - I think tap I have may be a bit worn as its taking huge pressure to cut (and I've checked it's straight) that I think if I try any harder it will snap..  So may have to go buy a good one or go for the Holeshot kit.  Or even an M7 which might cut itself in without tapping - a bit of a butcher job but with some loctite it isn't going anywhere.
Falcon 269
« Reply #16 on: 15 March 2012, 06:42:14 pm »
The correct tap is the one I showed above.  With that, the thread will cut like a hot knife through butter.  If the one you've tried isn't cutting like that, it's either knackered or there's something amiss with your technique. :)
At the risk of asking a dumb question, you are using grease on the tap ... ?
mark747eagle
« Reply #17 on: 15 March 2012, 06:55:47 pm »
Falcon
Yes using grease.  It's a tapered 8mm x 1.25  but made by Clarke.  I checked its alighnment - it will go in a few turns up to the end of the taper plus maybe a turn and then jam. Done the usual turning it back and forward but no joy.  I think I need a much better quality tap.
sadlonelygit
« Reply #18 on: 15 March 2012, 07:08:01 pm »
if you have a shiney new tap (£6) it will glide down the spigots. foccing about with a 10 yo well used tap will end in tears.
VNA - BMW Wank
« Reply #19 on: 15 March 2012, 07:14:16 pm »
I don't think I'd trust a Clarke tap for a job like that.
The Roebuck I linked to would be the minimum quality I would use.
Takes a wee bit of force to cut, but nothing major.
mark747eagle
« Reply #20 on: 15 March 2012, 07:29:55 pm »
Ok - I'll go for the good gear.  The Clarke tap required so much force i knew it would break if I went any further,
Falcon 269
« Reply #21 on: 15 March 2012, 08:59:27 pm »
Wise decision to stop.  Too many before you have pressed on regardless and learned a whole lot more engineering techniques that they didn't intend to as a result. ;)
mark747eagle
« Reply #22 on: 15 March 2012, 09:03:44 pm »
Yep.  Been there! Snapped off a few taps and easy-outs in my time.  Always ends in tears!
