Date: 01-05-26  Time: 08:22 am
Author Topic: Gen 2 Fz1s 12000 mile service schedule  (Read 4147 times)
Carlsv8
« on: 18 October 2016, 03:44:00 pm »
Could someone with an original hard copy Yamaha service schedule tell me exactly what is done on the 12000 mile service please, I've seen a download but this doesn't tally with what the bike shop is doing for a full service prior to me buying the bike, it is 8 years old with 10k on the clock. Not getting a good feeling about the shop but I've paid in full, schoolboy error, too trusting.
Cheers
Carl
Grayo
Re: Gen 2 Fz1s 12000 mile service schedule
« Reply #1 on: 18 October 2016, 04:51:57 pm »
12000 mile service schedule : (Taken from the owner's manual)
Check fuel hoses for cracks or damage.
Replace spark plugs.
Adjust synchronization of fuel injection system.
Check the air cut-off valve, reed valve and hose for damage. Replace any damaged parts if necessary.
Check operation of clutch and adjust if necessary.
Check operation of front and rear brakes, fluid levels and vehicle for fluid leakage.
Replace brake fluid and hoses every 4 years.
Check tread depth of tyres and for damage. Replace if necessary. Check air pressure. Correct if necessary.
Check wheel bearings for looseness or damage.
Check operation of swingarm and for excessive play. Lubricate with Lithium-soap-based grease.
Check drive chain slack, alignment and condition. Adjust and lubricate chain with a special O-ring chain lubricant thoroughly.
Check steering head bearings for play and steering for roughness. Lubricate with Lithium-soap-based grease.
Make sure that all chassis fasteners, nuts, bolts and screws are properly tightened.
Lubricate brake lever pivot shaft with silicone grease.
Lubricate brake pedal pivot shaft with silicone grease.
Lubricate clutch lever pivot shaft with silicone grease.
Lubricate shift pedal pivot shaft with silicone grease.
Check operation of sidestand and centrestand. Lubricate with Lithium-soap-based grease.
Check operation of sidestand switch.
Check operation of front forks and for oil leakage.
Check operation of shock absorber assembly and for oil leakage.
Check operation of rear suspension relay arm and connecting arm pivoting points.
Change engine oil. Check engine oil level and vehicle for oil leakage.
Replace engine oil filter cartridge.
Check coolant level and vehicle for coolant leakage. Change coolant.
Check operation of front and rear brake switches.
Lubricate moving parts and cables.
Check operation of throttle grip. Check throttle grip free play and adjust if necessary. Lubricate cable and grip housing.
Check operation of lights, signals and switches. Adjust headlight beam.
Carlsv8
« Reply #2 on: 18 October 2016, 10:22:40 pm »
Brilliant , many thanks. If the shop isn't reasonable I old be tempted to name and shame.
Graham53
« Reply #3 on: 18 October 2016, 11:00:23 pm »
Does anyone think dealers do all that in a service  how much is a mechanic labour at dealers per hour now and how long would it take to go through all that and you drop bike in at 8.30 for a service and they call you up at 2 to say it's done , even if they started at 8.30 which they don't it's a long list
Fazerjon
« Reply #4 on: 19 October 2016, 05:27:04 am »
I doubt very much that they would lube the head & swingarm bearings, just check for play. As for the coolant being changed you would have to look closely to see if there are any obvious signs, i.e. Radiator drain or hoses recently taken off or undone and coolant looking nice and fresh. I would guess at a check over,  maybe an oil & filter change and possibly a set of plugs. But I might be wrong......... :rolleyes
Mick-H
« Reply #5 on: 19 October 2016, 05:22:35 pm »
Doesn't take long to check and lube stuff, if nothing needs doing a couple of hours tops for a good mechanic.
Graham53
« Reply #6 on: 20 October 2016, 09:33:25 am »
Trouble is my last "service plus " as the dealer called it came to £320 , does anyone remember the days when biking was a cheap fun mode of transport, I love my gen 1, but bring back 2 smokes , what about a 500 lc fazer  :eek  , I saw not long ago Stan Stephens did a 1200cc V6 lc engine imagine that in a fazer ..... sorry gone well off topic
Carlsv8
« Reply #7 on: 29 October 2016, 04:20:22 pm »
Ended up with a full refund from the shop (more reasons than just the service) without any problems so cannot complain about the customer service after I decided that I wasn't happy, shop couldn't have been more helpful or professional; moral of the story is discuss the fine details exactly before parting with your cash. The bike hunt continues but probably going to wait until next year, unless a beauty comes along.
pilninggas
« Reply #8 on: 29 October 2016, 06:55:51 pm »
I service my Gen2 myself.
@12,000 miles I dropped the coolant and did the plugs.
There was no point; the coolant still tested fine and the plugs were in good nick. My 2pence is that the schedule is on the OTT side, and i'd be surprised if even franchised places did everything listed.
Fazerjon
« Reply #9 on: 02 November 2016, 08:20:12 pm »
I would imagine it would take more than a couple of hours to strip the front end out to lube the head bearings properly, and likewise with the rear end to lube the swing arm bearings properly, in addition to all the other checks that are "scheduled" to be done.
