Date: 03-05-26  Time: 06:23 am
Author Topic: disconnecting main keyswitch  (Read 1838 times)
ptolemyx
« on: 01 October 2016, 02:54:04 pm »
I want to completely remove the top yoke to respray it. How do I disconnect the wiring to the main key switch? Or will I have to drill out the (very hard) security bolts to remove the whole switch assembly from the top yoke????
I've downloaded the workshop manual and can't find an answer there.
NorthWestern
Re: disconnecting main keyswitch
« Reply #1 on: 01 October 2016, 05:11:05 pm »
I drilled mine out, wasn't that bad really
Intentionally left blank
NorthWestern
« Reply #2 on: 01 October 2016, 07:14:30 pm »
That is to say I was removing the barrel from the yokes. There is a connector block you can unplug if just removing the yokes
ptolemyx
« Reply #3 on: 02 October 2016, 05:45:17 am »
Disconnected at the connector under the tank. Now to drill and eazyout the bolts - simples really  :rolleyes
