Date: 03-05-26  Time: 23:20 pm
Author Topic: Carb o-ring size  (Read 1905 times)
shlomimor
Carb o-ring size
« on: 16 September 2016, 08:23:40 pm »
Hello
Does anyone check if this o-rings are correct dimensions?
All dimensions are in millimeters. The diameter listed is cross section of the o-ring cord. This is often times referred to as the width of an o-ring.
Main Jet: 5.5 ID x 8.5 OD x 1.5 DIA McMaster-Carr# 9262K519
Float Needle Fuel Valve: 7.5 ID x 10.5 OD x 1.5 DIA McMaster-Carr# 9262K629
Idle Air Screw: 3.0 ID x 5.0 OD x 1.0 DIA McMaster-Carr# 9262K441
Under diaphragm cap: 2.5 ID x 5.5 OD x 1.5 DIA McMaster-Carr# 9262K626
