Date: 15-05-26  Time: 09:52 am
Author Topic: fuel  (Read 4623 times)
Dustydes
fuel
« on: 21 August 2016, 08:47:42 am »
When does the fuel light come on, on your bike
Mine doesn't come on until the needle is just past the empty mark.
dickturpin
Re: fuel
« Reply #1 on: 21 August 2016, 10:31:20 am »
About the same...but tests have shown about a gallon left.
Dustydes
Re: fuel
« Reply #2 on: 21 August 2016, 10:57:47 am »
Thanks that's what I needed to know
Des
dickturpin
Re: fuel
« Reply #3 on: 21 August 2016, 12:47:24 pm »
If you want to check your own, run it dry, noting the milometer when the light comes on, but carry a fuel can with enough to get you to a garage...that's what I did.
donut
Re: fuel
« Reply #4 on: 21 August 2016, 02:01:27 pm »
Same here.
I'm a big bloke, and will squeeze circa 140/145 miles from full to fuel light, at which point it'll just about take 16 litres.
So I guess there's a good 3 litres left?
Tmation
Re: fuel
« Reply #5 on: 21 August 2016, 07:38:03 pm »
My bike has a multi gauge fitted and when it reaches 4L remaining the original fuel light comes on.
If I fill up straight way I get between 16 and 16.5L in. Tank is 21 L but as we all know the last 1L is a pain to get in.
I generally get between 145 and 180 miles before fuel light, depending on type of riding and load.
PaulSmith
Re: fuel
« Reply #6 on: 22 August 2016, 11:28:28 am »
On my normal commute, the fuel light comes on at about 160~170 miles and if I fill it instantly, it takes about 15 liters. If I run to 200miles on the odometer, it takes 18~19 liters. It has a 21 liter tank.
Dustydes
Re: fuel
« Reply #7 on: 23 August 2016, 07:26:39 am »
Thanks for reply's
As I had the clocks apart for white dials to be added I decided to set my fuel gauge to read empty with 5lts left in tank.
PaulSmith
Re: fuel
« Reply #8 on: 23 August 2016, 11:10:43 am »
Thanks for reply's
Why? 5 Liters is nearly 60 miles unless you are on a track. I would have thought a 3 liter reserve would be fine.
Dustydes
Re: fuel
« Reply #9 on: 23 August 2016, 12:47:36 pm »
5 ltrs allows for me being stupid and not noticing Im on empty. And as it makes no real difference, as in its not a reserve better to give myself a bit more time.
Also planning to ride in France and Spain next year. I have done a lot of driving over there and when off the main roads it can be hard finding a petrol station.
PaulSmith
Re: fuel
« Reply #10 on: 24 August 2016, 01:59:19 pm »
Fair points. Probably wouldn't work to well for me though as if the fuel light doesn't mean "think about getting fuel now!" then I would start to ignore it.
Dustydes
Re: fuel
« Reply #11 on: 25 August 2016, 01:50:21 pm »
Fuel light stays the same just the amount left when needle on empty
PaulSmith
Re: fuel
« Reply #12 on: 25 August 2016, 05:28:50 pm »
The needle pointing to E stays the same, the fuel light says I need to do something about it.
Dustydes
Re: fuel
« Reply #13 on: 25 August 2016, 05:46:45 pm »
The needle now points to empty with 5Ltrs left in tank, I haven't changed the amount of fuel left when light comes on. Don't know if you could, but I'm happy to leave it as it is.
