Date: 15-05-26  Time: 13:35 pm
Author Topic: Where on earth is the earth  (Read 2763 times)
windyg
« on: 20 August 2016, 04:49:05 pm »
Having a minor electrical issue so I am after picking your collective brains.
When I ride in heavy rain and sometimes after I have washed the bike I find that the
neutral warning light glows faintly when the bike is in gear , it also flashes alternately
with the indicator warning lamps when I use them.
My first thought is I have a faulty earth so my first question is does any one know where
the clocks earth ?
Second question is has any one else had this issue and how did you fix it.
Thanks in anticipation
Tmation
Re: Where on earth is the earth
« Reply #1 on: 20 August 2016, 07:29:10 pm »
The neutral switch is low down at the back of the engine and can get covered in crap.
check and clean the connectors.
jhaulass
« Reply #2 on: 23 August 2016, 11:54:07 am »
Same problem here, glowing neutral light when the bike is/has been wet.
I've cleaned the multiplug going into the back of the dials but that hasn't helped.
Any suggestions would be very much appreciated.
windyg
« Reply #3 on: 26 August 2016, 05:55:44 pm »
I opened up the connector block in the left hand side of the fairing and found some of the connectors had turned green. I have cleaned this out and used Vaseline to keep the moisture out but have yet to ride it in the rain so hopefully its fixed but time will tell.
