Date: 15-05-26  Time: 00:53 am
Author Topic: LED indicators  (Read 2381 times)
Ricky
LED indicators
« on: 18 August 2016, 09:58:10 pm »
I am hoping to fit a set of LED indicators to my Gen 1. I know I need to fit a different relay or resistors, but which is the best way to go? Is the relay easy to get, and where is it on the bike?
Fuzzygoth
Re: LED indicators
« Reply #1 on: 21 August 2016, 02:18:57 pm »
I am actually in the same boat, my rear indicators are corroded to all hell so I
thought I'd replace them with LED's but I am pretty sure I'll need and LED flasher
adaptor too to prevent hyper blinking on the indicators :/
If anyone has links to a good guide on how to do this it would be appreciated.
Fuzzy
Gabrael72
Re: LED indicators
« Reply #2 on: 21 August 2016, 05:15:45 pm »
If you change the indicators to LED's you need to lift the seat and check if you have a two prong or three prong relay, then just buy the one that's appropriate, real easy fix, no soldering involved, just plug and play!
Sent from my iPhone using Tapatalk
Fuzzygoth
Re: LED indicators
« Reply #3 on: 22 August 2016, 09:40:06 pm »
Excellent, so the relay is just under the seat then? that should make it fairly easy :)
