Date: 24-04-26  Time: 07:35 am
Author Topic: Simple DIY 6th gear position indicator  (Read 7189 times)
phil mcglassup
« on: 11 August 2016, 01:28:21 pm »
I know there are various gear position indicators available on the market but I am on a very tight budget and I'm fed up of trying to find seventh gear.
So, is it possible to make a simple DIY  top gear indicator ? Something that just produces +12v in top gear , i.e.  from an adapted neutral switch, to illuminate a bulb on the dash ? I remember seeing a fully operational homemade gear position indicator done a long while ago on a website which I can no longer find, but that involved complicated electronics  :eek
Has anyone ever done anything like this ?
misterjayb1
Re: Simple DIY 6th gear position indicator
« Reply #1 on: 11 August 2016, 02:33:58 pm »
My answer would be no, unless you wanted to use complicated electronics :) ..  Strangely I never look for a seventh gear when using the engine to its capabilities. Seems Im quite happy with just 5 in that mode..  :lol
« Reply #2 on: 11 August 2016, 04:34:25 pm »
A word of advice, stop looking for seventh gear, it simply ain't there!
phil mcglassup
« Reply #3 on: 11 August 2016, 05:49:14 pm »
 :D
Thing is I'm used to riding lower revving bikes so it's natural to want another gear  !!
Bretty
« Reply #4 on: 11 August 2016, 06:50:03 pm »
Something like this?
« Reply #5 on: 11 August 2016, 07:12:19 pm »
:D
I know what you mean, i rode a 600 twin for about 10 years before this one, so the Fazer does appear rather highly strung most of the time.
misterjayb1
« Reply #6 on: 11 August 2016, 10:05:20 pm »
:D
Unlearning the short shifting I'd got used to on my Ducati Monster is proving difficult at times..  :rolleyes
phil mcglassup
« Reply #7 on: 11 August 2016, 10:33:25 pm »
I just thought there might be an easy modification to add another terminal, in the correct position, to the neutral light switch and use that to illuminate a bulb on the dash. When the bulb is lit, the bike is in top gear. Is this possible ?
celticdog
« Reply #8 on: 12 August 2016, 01:13:38 am »
Indeed. Take a look at your revs, you'll find that you'll start to match the gear to the speed as you get to know the bike  :)
if i'm doing 60 mph i know i'm in top gear if the rev counter's a 5000 rpm. :rollin :rollin :rollin
« Reply #9 on: 12 August 2016, 05:36:06 am »
It's also why having overly loud end cans can be tiresome if you do longer runs, because the noise drives you insane after a while.
Good fun if you're just zipping about in the suburbs, but on a motorway run it does get monotonous especially because of the higher revs.
You can change the sprocket teeth size to bring down the revs a bit if you find yourself having to use 6th gear for longer periods of time.
characticus
« Reply #10 on: 12 August 2016, 12:19:32 pm »
No its not possible to do that without some electronics to detemine if you're in top gear - be much easier just to fit a gear indicator.
joebloggs
« Reply #11 on: 12 August 2016, 01:10:46 pm »
Providing you're not suffering terminal clutch slip just count your way through the gears to make sure you're in sixth then remember revs at your normal cruising speed.
Simples
YamFazFan
« Reply #12 on: 13 August 2016, 03:16:43 pm »
My (completely standard) Foxeye reads 5650 RPM at 70 MPH in top gear.
mr self destruct
« Reply #14 on: 17 August 2016, 03:34:07 pm »
On my stock bike, in 4th the speed matches the revs, i.e. 40mph = 4000rpm so that could give a good indication too.
schlumpf
« Reply #15 on: 18 August 2016, 09:42:30 pm »
Look at this one!
https://www.amazon.co.uk/Universal-Digital-Gear-Indicator-Motorcycle/dp/B00EM8AH1I/ref=sr_1_65?s=automotive&ie=UTF8&qid=1471443007&sr=1-65&keywords=motorcycle+accessories
This appears to be a simple display w/o any brain. Doesn't help here.
In my view there are 3 ways to get the gear informations:
- Take one of those reed contact based devices from china. Very cheap (~15EUR?). Unfortunately need some ugly installation around the gear lever and might be tricky to adjust reliably.
- Those "Acumen type" indicators tap the electronic's signals and calculate the gear. No mechanics, just wiring. Cheap clones start at ebay in the range of ~50EUR.
- A few people started designing their own gear indicator. Good choice if you are not afraid of soldering.
http://www.alpentourer.de/shop/ganganzeige/ganganzeige.html
http://fireblade_chris.hp.altmuehlnet.de/Ganganzeige_SC57.htm
http://www.jn-elektronik.de/?page_id=25
http://cvieth.bplaced.net/ganganzeige_mini.html
As you are very sensitive on price my suggestion would be the first option, reed contact type.
Robgosty
« Reply #16 on: 19 August 2016, 05:18:52 pm »
I got one of these, does the job really well and costs buttons compared to others  :D
http://www.ebay.co.uk/itm/121325993344?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Val
« Reply #17 on: 20 August 2016, 12:55:06 am »
Thanks for that I bought one for £18 what could go wrong  :lol
I really like the clarifications there:
Quote
If your motorcycle is a front-wheel drive, you need professional maintenance staff installed
« Reply #18 on: 20 August 2016, 07:25:42 am »
By the time it's fitted you would've got used to the sound and feel of the engine and you won't even need it.  :lol
jackw96
« Reply #19 on: 20 August 2016, 11:16:36 am »
I was doing the same thing for the first few months of owning a fazer. I went from a single cylinder to a buzzy 4 banger. Just get to know where the revs are at certain speeds in top gear.
paulchucky
« Reply #20 on: 23 August 2016, 08:02:54 am »
phil
simple answer learn to twist your wrist more
it will make you  :) :) :) :) :)
