Date: 14-05-26  Time: 13:36 pm
Author Topic: Multi-Gauge  (Read 10506 times)
teecee90
Multi-Gauge
« on: 06 August 2016, 08:31:17 am »
Hi
I've ordered one of the multi gauges to replace the fuel gauge. Has anyone who has fitted the gauge used the speedo healer function just to get a more accurate speedo reading with standard gearing? If so, how did you set it up please?
Falcon 269
Re: Multi-Gauge
« Reply #1 on: 06 August 2016, 10:27:58 am »
Christian, the guy who makes these, will be able to tell you how to do that. :)
I imagine you would need to compare speedo with a GPS-derived speed to find the initial variation, which will almost certainly be speedo over-reading, then enter a speedo adjustment factor to bring the two closer together.  Might need a bit of trial and error.
tex
Re: Multi-Gauge
« Reply #2 on: 06 August 2016, 01:06:48 pm »
Also pats site has a good right up on it, although I think it's more if you change the sprocket size. There's a good insulation guide
Falcon 269
Re: Multi-Gauge
« Reply #3 on: 06 August 2016, 01:09:40 pm »
Pat's Site has explanations on how to use the Yellow Box recalibrator and the Speedohealer recalibrator, plus instructions on how to fit a Multigauge.
I had a quick look and couldn't see instructions in the Multigauge bit covering settings for the speedo correction function in that unit.  I might be wrong, though. :)
stevegixer
Re: Multi-Gauge
« Reply #4 on: 06 August 2016, 01:21:54 pm »
Hi
Have you got a link to the multi guages please  :)
tex
Re: Multi-Gauge
« Reply #5 on: 06 August 2016, 02:00:01 pm »
It's down the bottom of the insulation guide mike, under speedometer correction, ☺
teecee90
Re: Multi-Gauge
« Reply #6 on: 06 August 2016, 02:01:13 pm »
Don't ask me how I know, but the satnav registered 137mph when the speedo was touching 150, so it seems quite a way out. Not sure how typical that is.
This is the link to the English summary of Christian's web page.
http://cvieth.bplaced.net/ganganzeige_summary.html
To place an order just email him: cvieth@vodafone.de
teecee90
Re: Multi-Gauge
« Reply #7 on: 06 August 2016, 02:08:02 pm »
Ah yes - just read the full page on Pat's site ..... :o
Must learn to read things all the way through rather than just skim over things  :lol
Dustydes
Re: Multi-Gauge
« Reply #8 on: 06 August 2016, 02:12:04 pm »
Look under: How to use, opens a PDF
Falcon 269
Re: Multi-Gauge
« Reply #9 on: 06 August 2016, 05:39:30 pm »
Got it now, Tex, thanks. :)
stevegixer
Re: Multi-Gauge
« Reply #10 on: 06 August 2016, 10:17:38 pm »
How much are they ?
Where from ?
Are they easy to wire in ?
Mick-H
Re: Multi-Gauge
« Reply #11 on: 07 August 2016, 08:41:27 am »
How much are they ? .................... Can't remember
Where from ? ...................... Christian
Are they easy to wire in ? ...................... Not if you don't know how to do it.
Hope that helps
stevegixer
Re: Multi-Gauge
« Reply #12 on: 07 August 2016, 03:45:37 pm »
Hope that helps
Sort of helps cheers.but who is christian ?
teecee90
Re: Multi-Gauge
« Reply #13 on: 07 August 2016, 04:40:00 pm »
Christian Vieth, the guy who makes them.
stevegixer
Re: Multi-Gauge
« Reply #14 on: 07 August 2016, 05:39:58 pm »
What's the price on them ?
ArchDruid
Re: Multi-Gauge
« Reply #15 on: 07 August 2016, 10:34:53 pm »
My experience is that most vehicles on the road today have speed readings that are overstating reality by as much as 10%. So your GPS measurement of 137 compared to your speedo's 150 is about right.
(perhaps this also has something to do with the 'margin' that the traffic dept allows you before the speed camera takes your pic ... but that's a different topic all together ...)
BTW,  I have the multiguage fitted in mine (lucky enough to come with the bike) ... Fantastic piece of kit !!!
Having read through the installation instructions & the operating instructions, I reckon it should be quite easy to adjust for the correct speedo reading. The difficult bit (actually not 'difficult', just labour intensive) will be to solder the wires in the correct places ... but its all well detailed in the docs.
Fazerjon
Re: Multi-Gauge
« Reply #16 on: 08 August 2016, 06:19:35 pm »
I've just emailed Christian they are €147 which equates to roughly £124 delivered.
old son
Re: Multi-Gauge
« Reply #17 on: 15 August 2016, 07:02:05 am »
Worth every penny!!!!
teecee90
Re: Multi-Gauge
« Reply #18 on: 15 August 2016, 11:52:45 pm »
I set the speedo healer function to 95% and it's now pretty much spot-on compared to the satnav.
Scotfaze
Re: Multi-Gauge
« Reply #19 on: 16 August 2016, 09:24:59 am »
Does anyone know anyone in the Glasgow/South Lanarkshire area that can fit one of these multi gauges as I'm thinking of buying one.??
Cheers.
Tefer
Re: Multi-Gauge
« Reply #20 on: 16 August 2016, 09:27:58 am »
Cheers.
I am also thinking of buying one, in the future so would be handy to know too. I am no good with a solder.
Fazerjon
Re: Multi-Gauge
« Reply #21 on: 16 August 2016, 10:55:04 am »
Roll on payday, I'm going to invest!
tex
Re: Multi-Gauge
« Reply #22 on: 16 August 2016, 11:49:54 am »
Cheers.
 Your local computer shop should be able to do it for you.
