Date: 19-04-26  Time: 17:07 pm
Author Topic: Ignition key barrel maintenance?  (Read 2971 times)
dickturpin
« on: 01 August 2016, 05:07:56 pm »
So....clever folk of the forum.....is it a good maintenance policy to spray WD40, or contact cleaner, or nothing at all down the key barrel once in a while?
slappy
Re: Ignition key barrel maintenance?
« Reply #1 on: 01 August 2016, 05:48:05 pm »
I use wd40 to flush ignition and door locks etc out then graphite powder lube to keep them lubed :)
dickturpin
« Reply #2 on: 01 August 2016, 07:12:08 pm »
With no detrimental effects on the electrical contacts?
slappy
« Reply #3 on: 01 August 2016, 08:11:46 pm »
No detrimental effects that I have noticed, do it about once a year when I service bike or car.
Frosties
« Reply #4 on: 01 August 2016, 08:36:24 pm »
I don't use the WD but regularly use the graphite lube (linky below) on bike, car, doors etc when they start to catch a bit - lasts a 'kin long time.
https://www.arco.co.uk/product?productcode=3450025&OID=614336
« Reply #5 on: 01 August 2016, 09:01:13 pm »
I did a bit of research on this and found that graphite lube is great stuff on dry locks, but not so much in wet conditions when it turns into a mush.
nickodemon
« Reply #6 on: 01 August 2016, 10:07:23 pm »
This stuff is great for any ignition locks and stiff padlocks etc..
http://www.ebay.co.uk/itm/291803898148?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
« Reply #7 on: 01 August 2016, 11:06:08 pm »
That's more like it.  :thumbup
Whatever you use will always be better than nothing though.
A 400ml can of this stuff should also last you approximately 40 odd years as well, so in the future will be money well spent.  :lol
« Reply #8 on: 02 August 2016, 07:26:56 pm »
I use wd 40 first and then plain waterproof grease, never an issue with the any locks/Ignition switches
dickturpin
« Reply #9 on: 02 August 2016, 09:47:48 pm »
Well I have now given all locks a blast of wd40 followed by a quick spray of PTFE lube.
Thanks gents...
D
Val
« Reply #10 on: 03 August 2016, 12:44:19 am »
I use to use it. Now I never use anything that may cause me problems with electrical contacts. I have got some issues with my bike not starting two months ago. I flushed the ignition lock with a lot of electrical contacts cleaner. Problem solved.
Now I prefer my ignition lock not lubed, on the bright side the bike starts each time fine.
Mick-H
« Reply #11 on: 06 August 2016, 05:53:59 pm »
I use Wurth chain lube on mine, no problems so far.
Slaninar
« Reply #12 on: 06 August 2016, 07:45:59 pm »
Dry locks (not out in the elements) - graphite.
Outside - WD40, then a bit of teflon spray.
