Date: 15-05-26  Time: 01:58 am
Author Topic: Headlight Problem - Not coming on with ignition.  (Read 1955 times)
dangerousdave
« on: 30 July 2016, 06:36:22 pm »
Hi there, wonder if anyone can help.
My headlights are not coming on when I start the bike. (2003 Gen1 FZS1000)
Neither dipped or full beam (sidelights are OK).
I have checked the fuse and both lights flash with the pass switch.
Any suggestions?
Dave...
Dustydes
Re: Headlight Problem - Not coming on with ignition.
« Reply #1 on: 30 July 2016, 07:25:57 pm »
Not had problem with a bike
But a car of mine had same problem.
Could pull back stalk and lights would flash but not stay on, it turned out to be the switch itself was toast.
You could try removing switch and spray with good old WD40, couldn't hurt.
Good luck
dangerousdave
« Reply #2 on: 30 July 2016, 10:54:36 pm »
Hi Dustydes,
Thanks for your reply but headlights come on when the bike is started, unfortunately there is no light switch.
Dustydes
« Reply #3 on: 31 July 2016, 07:10:52 am »
Lights will flash with pass switch as it bypasses the high/low beam switch which could still be faulty.
Failing that try the relay.
Side light wont go through relay due to low amp's so will work as separate from High/Dip.
Without a wiring diagram I'm guessing but its normally the case
sirgalahad3
« Reply #4 on: 31 July 2016, 07:12:21 am »
Take screen off and check connections at the 2 headlight relays you will see at the bottom of the screen.
If I remember correctly ecu sends a negative down the white wire to the relay when the engine has fired to bring on lights. Check wiring diagram to confirm etc. Could be a duff relay but they are normally reliable..
Before this check LOW beam filaments on both bulbs......
