Date: 01-05-26  Time: 05:41 am
Author Topic: left hand engine seals.  (Read 3611 times)
Bretty
« on: 26 July 2016, 11:21:47 am »
I changed my gearbox over, over Christmas. I replaced all of the gaskets at the time but reused all the seals on the left-hand side of the engine (clutch rod, gear shift shaft and gearbox output shaft seals). They all looked to be in good condition at the time, so I put gasket seal on the outside of them and stuck them in.
I now have a slow leak / drip coming from that side now, which I think is likely to be the output shaft seal.
I've bought a whole set of seals and plan to replace them. I'm now trying to get my head around... How easy is that to do without splitting the engine? I'm hoping I can just pull the shafts out then hook the seals out? Output shaft might be a bit trickier to get out? Will I need to drain the oil?
Hmm
His Dudeness
Re: left hand engine seals.
« Reply #1 on: 26 July 2016, 05:45:10 pm »
As long as the seal doesn't have a lip on the inner edge you should be able to press it in from the outside without taking the engine apart.
