Date: 08-05-26  Time: 23:05 pm
Author Topic: stuttering fzs 600  (Read 389328 times)
Re: stuttering fzs 600
« Reply #1050 on: 27 December 2014, 08:53:06 pm »
Now this is what I call a winter warmer     :lol
Oh no :groan
What have we done
« Reply #1051 on: 27 December 2014, 08:57:00 pm »
Anything you can do  :pokefun.......should put this in "highlight of the year "thread, all sorted now and running as good now as when I bought it some 14 ish years ago   :D
3legs
« Reply #1052 on: 08 March 2015, 01:09:08 am »
Hello all
I have today bought a 1999 600. it has done 32000 miles and is quite tatty - I only paid £650 for it though
I have previously owned 2 x 600 early fazers, 2 x thundercats and a naked FZ6 - so I must like them!!
It has a Scorpion race can on it and I took it for a test ride before I bought it- it rides ok, but did have a stutter on full throttle. I put it down to having a race can on it and that it has been stood for a year. I plan to put the standard can back on, put new plugs in and have the carbs balanced.
I read with interest this thread and it was good Saturday night reading!!
The paintwork is tatty so was planning on having it re-sprayed professionally. maybe a current white colour?
I hope that the above work will make it run properly, but will keep you guys informed
Paulfzs
« Reply #1053 on: 08 March 2015, 04:12:54 pm »
this made for a funny read lol
midden
« Reply #1054 on: 07 March 2017, 10:47:49 am »
I don't normally read books let alone full blown novels but having completed this one i've  learned that it really is best to read the end first  :rollin
So as i now appear to be suffering a bad  'stutter'  (started mildly last year i think)  im going to get the multimeter out and start with testing the regulator.
Hopefully posting your trials & t's Paul will help ease mine, after a few paracetamol ofcourse  :\
« Reply #1055 on: 07 March 2017, 06:56:02 pm »
Hi neil........chapter 2 is all yours   :rolleyes .....keep us updated .....
Lex162
« Reply #1056 on: 25 June 2017, 05:24:55 pm »
I've got the same problem :( Bike has an aftermarket can and pipes, my regular mechanic suggests it could be down to this.
So far I have done the following (some just because it needed it):
  • Oil and Filter change
  • New Spark Plugs
  • New Spark Pug Caps
  • Brake Fluid change
  • Carbs Balanced
  • Checked air filter - looks pretty good still
  • TPS Checked and all good
  • Replace Coils
Still to do:
  • Regulator/Rectifier
Anyone have any other thoughts as I'm committed to fixing it now!
« Reply #1057 on: 26 June 2017, 06:11:02 am »
  • New Spark Plugs
  • Carbs Balanced
Still to do:
  • Replace Coils (waiting for them to arrive, not very patiently)
Did you cut about 10mm off the end of the HT leads when putting the new caps on? The internal wires get pushed into the outer cover of the leads over time making the connection to the cap screw not as good as it can be.
Do a quick TPS check and make sure that's positioned correctly.
Replace the fuel filter.
Difficult to suggest an air filter "looks okay", do you know the history of it? If not change it, personally i would go for a K&N, but if not don't buy the cheapest one you can find as they can be crap.
« Reply #1058 on: 26 June 2017, 12:25:22 pm »
i read earlier about sealed in ht leads to the coils
i cannot garruntee on the fazers but these often can be redone with a bit of time and patience
i did some on my gsx1100 chop build i just used a bradawl and a little screwdriver while sat in the garden watching youtube
just started picking out the epoxy that was holding in the ht leads then yanked it hard (then got back to working on coils)
once out i was able to clean up the surfaces with screwdriver scraping, inserted new HT's and a bit of epoxy, job done
Lex162
« Reply #1059 on: 27 June 2017, 09:42:24 pm »
Thanks for the thoughts.  Forgot to mention that I'd checked the tps.
I'll order an air filter :)
running out of patience and cash to throw at it.
« Reply #1060 on: 27 June 2017, 10:52:32 pm »
Just bear in mind, "if" your air filter was clogged up, then the air would've been struggling to get to the carbs, which in turn would give you a false reading on a carb balance.
So if it starts running ropey with a nice clean air filter then that could be the reason.
It's unlikely but certainly possible, as i found out myself.
rlkat
« Reply #1061 on: 12 August 2017, 09:30:02 pm »
.ok fazer fans......wow,what a thread  :o .....thought it time i thanked everyone who posted and helped with "the stuttering one"....i couldnt of done it without you......CHEERS FOCCERS......with special thanks to ,FAZERIDER...ADETHEBLADE ... AND CRH
a picture to finish this thread off....well worth all the time and effort.........next epic thread "how to polish downpipes"... :lol
looks better in the flesh.....the red is a lot ....redder :lol
What an epic thread. Just read the whole lot. You, sir, have the patience and persistence of very patient and persistent thing. Glad you got it sorted.  :thumbup
rob
« Reply #1062 on: 13 August 2017, 07:54:00 am »
hi rob.......not sure about my patience levels  :lol , lost my temper a few times and walked away  :wall .....
i did cheat however , i bought myself a second fazer half way through the saga , a mighty thou which i still have...
the "stuttering one" is still running fine and approaching 50,000 miles ,owned for 15+ years and still enjoy riding it..
was it worth all that hassle ?........course it was, its a RED 600 BOXEYE , fastest of the lot   :D
