Date: 09-05-26  Time: 04:38 am
Author Topic: Back steer light is not working  (Read 2216 times)
krystof.ka
« on: 04 July 2016, 12:27:18 am »
Hello,
my back left steering light stopped working and the front one on the same side is flickering really fast. Could I please ask you for an advice what to do?
Kind regards
 Krystof
His Dudeness
Re: Back steer light is not working
« Reply #1 on: 04 July 2016, 05:46:09 am »
The bulb has probably come loose or blown. Take the cover off the one that's not working and have a look at the bulb. Check for corrosion in the bulb holder. A spray of wd 40 and a wiggle of the bulb should fix it if it's not blown
krystof.ka
« Reply #2 on: 04 July 2016, 01:08:38 pm »
Unfortunately, this didnt help. Thank you. K
« Reply #3 on: 04 July 2016, 01:16:02 pm »
If the bulb and socket are OK, check the connections to the socket and the flying leads at the frame end of the indicator stalk.
Jules-C
« Reply #4 on: 04 July 2016, 08:29:28 pm »
Most likely is the bulb is blown.  Swap it with  one from the other side and see if the problem moves to the other side as well
