Date: 15-03-26  Time: 02:48 am
Author Topic: Chain rivet query  (Read 4223 times)
Shinigami
Chain rivet query
« on: 27 June 2016, 11:16:41 pm »
Reeto,
I've whacked a new set of sprockets and chain on the fz6, however the cheap peice of shit riveting too I had has apparently got a riveting bit that's softer than the rivet...
so I've  been trying to bash the rivet to flare it and used whatever i could find to do so, however i'm not sure how much is enough to not result in all of the death.
Is the pic below flared enough?
https://goo.gl/photos/TgjaqZhwjwGGyCb48
Megawatt
Re: Chain rivet query
« Reply #1 on: 28 June 2016, 12:26:17 am »
Looks good to me. I use two hammers when I rivet a link.
Shinigami
« Reply #2 on: 28 June 2016, 09:44:10 am »
the rivet end was a lot tougher and harder than I expected, had to give it a fair number of taps to get it like this..
is that normal? everything i tried to push in the hole to flare ended up worse off than the rivet end  :rollin
Megawatt
« Reply #3 on: 28 June 2016, 12:28:06 pm »
Yes some rivets don't have a big enough hole in the middle and don't flare out.  I put a lump hammer behind the rivet link and tap the front with a ball pein hammer to flare it over just enough.
Shinigami
« Reply #4 on: 03 July 2016, 10:59:45 pm »
they weren't flared enough, I went an acquired a digital caliper and a riveting pin from a motion pro tool and bodged it into my cheap chinese tool which did the job fine then  :lol
