Date: 06-05-26  Time: 06:32 am
Author Topic: Fork play.  (Read 1915 times)
Bretty
Fork play.
« on: 31 May 2016, 12:10:06 am »
My bike has developed a slight 'knock' or looseness in the front fork.
I'm pretty sure it's not the headset as when I put on the front brake and rock backwards and forwards I can't replicate it. It's just when riding and over bumps. Is it likely to be worn bushes?
I've never had a fork apart before. What part is likely to be knackered and what other spares should I get?
Thanks,
celticdog
Re: Fork play.
« Reply #1 on: 31 May 2016, 01:38:06 pm »
Hi Bretty, the first thing I'd do is rule out wear on the headset and front wheel bearings before you start to dismantle the forks.
Have you made sure everything is 'tight' and properly torqued at the front end? Changing the fork oil to 15w could make all the difference. :)
