Date: 25-05-26  Time: 23:15 pm
Author Topic: FZS 1000 neutral issue  (Read 2816 times)
msewelly
« on: 10 May 2016, 12:41:17 pm »
Hi, my neutral light does not come up on the dash. The bike only starts when its on the centre stand and won't start with the side stand down, even when its in neutral.
I've given the side stand switch a clean and checked the connection at the blue connector which seems fine but I'm still not to sure where to look. There is a clicking noise at the box under the left hand side black panel by the seat when I pull the clutch in but that could possibly just be normal?
Any suggestions?
Thanks!
CaptainCazador
Re: FZS 1000 neutral issue
« Reply #1 on: 11 May 2016, 01:35:08 pm »
Give the starter solenoid a wiggle if that fails try bump starting.
AyJay
« Reply #2 on: 11 May 2016, 09:10:43 pm »
The neutral switch on the back of the engine might have failed. Mine did ages ago. This post might help
http://foc-u.co.uk/index.php/topic,3104.msg24875.html#msg24875
SkidT
« Reply #3 on: 14 May 2016, 08:50:52 pm »
I've also just had my neutral light switch replaced. IIRC it was about £30 odd from Yamaha.
