Date: 11-05-26  Time: 23:44 pm
Author Topic: Tourque arm  (Read 3499 times)
Tourque arm
« on: 09 May 2016, 10:05:15 pm »
Whilst I was refurbing my centre stand I decided to do the torque arm, one bolt came off ok but the other got rounded a little (Yamaha cheese metal) I have re filed some flats on to it but could do with a new nut, but what is it? its like a nylo nut but instead of the nylon it has a bit of metal that sort of digs in.
Also what torque should I re do at
celticdog
Re: Tourque arm
« Reply #1 on: 09 May 2016, 10:58:07 pm »
This is from the service manual, but it's just a guide. Stick up a pic of the nut fella, I'm sure you can source a cheaper replacement.
Re: Tourque arm
« Reply #2 on: 09 May 2016, 11:26:51 pm »
Here it is and it fits on the bolt without a washer
Re: Tourque arm
« Reply #3 on: 10 May 2016, 01:42:19 pm »
So what are these nuts called and I assume that any kind of torque setting is not really necessary on those nuts as
1 you dont want to end up snapping the swing arm mount
2 the nuts are designed not to come undone - self gripping with the metal slither
3 the arm is doing all the work and the nuts and bolts just hold it there.
What is the focer wisdom here
One more thing today is wet and damp and I have just sprayed the arm and the paint has gone matt, so I have re coated and brought it inside to dry
risticuss
Re: Tourque arm
« Reply #4 on: 10 May 2016, 03:50:06 pm »
The nuts are usually called "all metal locking nuts" either The nuts are usually called "all metal locking nuts" either with a flange or not. There are loads of different types.
Try these:
http://www.dsfasteners.co.uk/#!self-locking-flange-nut/c19vc
Or Probolt do them too:
http://www.pro-bolt.com/catalogsearch/result/?material=504&q=Flanged+lock+nut a flange or not. There are loads of different types.
Try these:
His Dudeness
Re: Tourque arm
« Reply #5 on: 10 May 2016, 05:07:14 pm »
think that nut is 23NM. page 7-62 of the yamaha workshop manual
Re: Tourque arm
« Reply #6 on: 10 May 2016, 07:07:02 pm »
Thanks chaps re- torque and nut supplier -- but my those are expensive I think though I have found the correct name for the type after risticuss pointed me in the right direction, they are called Satytite
Another question-- why would all metal staytite nuts be used on the arm as opposed to nylon lock ones
joebloggs
Re: Tourque arm
« Reply #7 on: 10 May 2016, 07:24:27 pm »
Just guessing tbh but I would say all metal can be undone and tightened many times while the nylock would need replacing more frequently
Re: Tourque arm
« Reply #8 on: 10 May 2016, 07:57:29 pm »
NOW THEN that may bring us back to this mamoth debate http://foc-u.co.uk/index.php/topic,14772.0.html, after all the workshop documentation not saying you need to loosen - it looks like the designers at Yam have designed into the arm a facility to enable frequent loosening and tightening suggesting that is what you should do.  :lurk
Re: Tourque arm
« Reply #9 on: 12 May 2016, 07:01:40 pm »
Yep you are right - now all done resprayed re greased although only did to 20nm but I dont think they are going to come undone as they are all metal locknuts but I will keep an eye on them.
