Date: 07-05-26  Time: 04:24 am
Author Topic: Gasolin from the carburetors  (Read 1974 times)
Bimbam
« on: 05 May 2016, 03:15:18 pm »
Hi. Just took my wonderful 1998 Fazer out for the first ride this year. The carburetor’s nr. 2 and 3 is dripping gasoline. Any idea? Is it the Oring from the floaters house or?
It started dripping when the fuelpumpe had finished making pressure.
His Dudeness
Re: Gasolin from the carburetors
« Reply #1 on: 05 May 2016, 04:30:09 pm »
the float needle is probably stuck open from old petrol. it's time to give those carbs a clean
Bimbam
« Reply #2 on: 05 May 2016, 04:39:41 pm »
How do i remove / clean the float needle? Can it be done when the carbs is on the bike?
His Dudeness
« Reply #3 on: 05 May 2016, 04:47:40 pm »
It'd be very fiddley to do it with the carbs still in the bike. I wouldn't try it. There's not a lot of access and the float bowls screws are usually hard to undo. You'd be better off taking them out and doing it on the bench
« Reply #4 on: 05 May 2016, 06:48:54 pm »
 :agree...yep, carbs out jobbie......not much room with the carbs in place, while your in there check the float height aswell  .
nice bike you got there......same as mine  :thumbup
Bretty
« Reply #5 on: 05 May 2016, 11:17:59 pm »
It might be worth checking the fuel pipe / connection / connector on the top of the carburetor before you pull everything out. The hose can perish.
(there are 2 coolant hoses too, I've had one of those go before, although I'm sure you know the difference between fuel and coolant)
Carbs out and strip I managed in a long afternoon. It's easy enough with a Haynes manual, a decent set of screw drivers and arms like Mr Tickle.
