Date: 27-03-26  Time: 10:28 am
Author Topic: Rear sprocket nuts/bolts  (Read 3192 times)
sinto
« on: 02 May 2016, 07:06:02 pm »
Just wondering if anyone's had a problem replacing the rear sprocket nuts/bolts?
I've just recently put on new chain and sprocket set but on looking at them again today I'm thinking I might of sheared 1 of them :(
How easy are they to replace or do I need to get a whole new carrier?
Cheers.
Re: Rear sprocket nuts/bolts
« Reply #1 on: 02 May 2016, 09:06:13 pm »
They are studs which screw into the hub. I have found normally the threads in the nut strip before the stud shears.
sinto
« Reply #2 on: 02 May 2016, 09:10:14 pm »
Cool so just some new nuts 'oh err missus' are needed?
Standard nuts or best going to ajsutton etc?
£41.16 to get a full set from Sutton or £20.16 to just get the nuts, either way cheap enough for peace of mind I think :)
joebloggs
« Reply #3 on: 03 May 2016, 05:29:10 am »
sinto
« Reply #4 on: 03 May 2016, 09:03:40 am »
The nuts are M10 x 1.25. You can find stainless flanged nuts on ebay cheaper than Yamaha items, no rust either  :D
http://www.ebay.co.uk/itm/M10-X-1-25-STAINLESS-STEEL-FLANGE-NUTS-FINE-THREAD-PITCH-10mm-x-1-25mm-serrated-/231828370889?var=531071993189&hash=item35fa0c35c9:m:mdAcE1IULzJkpSMiHKEwZow
Cheers Mr bloggs,
Wont I need some form of springs washer for these as original yamaha ones have nyloc in them? Guessing a tube of locktight will do the same job :)
joebloggs
« Reply #5 on: 03 May 2016, 07:52:27 pm »
Their serrated so when you torque them up they'll bite into your sprocket. You could use thread lock but they should stay put.
I'll always swap for stainless, cheaper than standard and no worries about rusty nuts
sinto
« Reply #6 on: 03 May 2016, 08:21:55 pm »
:thumbup
I've never liked the idea of having rusty nuts :rollin :rollin :rollin
