Date: 06-05-26  Time: 20:48 pm
Author Topic: me again rumbling/metalic sound  (Read 3733 times)
chrischristopherson1313
« on: 29 April 2016, 11:57:07 pm »
There is a frequent sound from bottom or  front of the bike.
The frequency is higher when speed is higher. Progress with the speed.
It doesn't mater what gear it is or neutral.
I thought the is a problem with breaks or bearings but when I wheel the wheel I can't hear anything?
Can this sound be from somewhere else then wheel.
joebloggs
Re: me again rumbling/metalic sound
« Reply #1 on: 30 April 2016, 05:52:56 am »
Try removing your front wheel and turn the bearing with your fingers, if it has tight spots or feels rough when you turn it then they'll need replacing.
May not be your problem but an easy one to check
« Reply #2 on: 30 April 2016, 06:12:50 am »
Not really precise enough, but have you recently done any work on the bike?
« Reply #3 on: 30 April 2016, 09:36:25 am »
If I know precisely I would fix it:)
The noise it's constant even when breaks applied.
I need to try to go for a hill and go on the bike with engine off then I know if it's engine.
I have ordered front bearing they are really cheap anyway.
andybesy
« Reply #4 on: 30 April 2016, 11:57:36 am »
Could well be the bearings, but binding brakes can cause this too, even when applied. Had that recently and just standard post-winter clean sorted it. Suggest give em a clean at same time as inspecting your bearings.
Andy
« Reply #5 on: 07 May 2016, 10:03:40 pm »
Andy
So it were the bearing.
Changed them now ( wasn't easy to take off old one!!!) And bike it's like new:)
andybesy
« Reply #6 on: 07 May 2016, 10:06:28 pm »
Good, glad you got it sorted.
Andy
