Date: 06-05-26  Time: 17:31 pm
Author Topic: front sprocket nut  (Read 27006 times)
chrischristopherson1313
front sprocket nut
« on: 26 April 2016, 08:33:00 pm »
Nut on the front sprocket it's loose. I can screw it with my fingers (not even using power)
Is it normal or it should be tight.
The screw it's still on the shaft hold by washer
Re: front sprocket nut
« Reply #1 on: 26 April 2016, 09:17:12 pm »
It should be tight, but it is a common problem.
http://foc-u.co.uk/index.php?topic=92.0
« Reply #2 on: 26 April 2016, 09:27:39 pm »
Ok luckily the nuts didnt come of yet
I have ordered bigger nut from yamaha.
Do you think it's safe to run a bije for those couple of days until new nut come?
« Reply #3 on: 26 April 2016, 09:40:23 pm »
No, it's really not to be recommended.
Having said that, the early Fazers have a plate screwed to the inside of the sprocket cover which prevents a loose nut from actually falling off the end of the shaft and a lot of us have probably ridden quite a long way with it in that condition without realising.
His Dudeness
« Reply #4 on: 26 April 2016, 10:28:45 pm »
What condition are the threads in?
« Reply #5 on: 26 April 2016, 10:51:29 pm »
Was trying unscrew with fingers only. Although it's loose doesn't come of so proboly thread it's damaged a little. Will wait for new nut first and then will try to unscrew it.
« Reply #6 on: 27 April 2016, 06:28:02 am »
Can i just ask what the exact year of your bike is please on behalf of someone elses curiosity?
« Reply #7 on: 27 April 2016, 08:09:35 am »
1988
tommyardin
« Reply #8 on: 27 April 2016, 08:44:10 am »
These front sprocket nuts are a real problem it seems. As I mentioned in another post on here my 2003 FZS600 foxeye still has the original 9mm nut fitted, I have the upgrade kit 12mm nut and washer on the bench in my shed ready to go, but, try as I may I cannot undo the one that's on the bike.
I have straightened out the lock/tab washer 32mm socket with 500mm bar and put all the pressure I can on it, had a mate sit on bike, in gear, brakes on and fucking near burst a blood vessel trying to loosen that bastard to no avail. One of the other foccers in here came up with the solution which I have yet to do, that is ride down to a friendly mechanic pop the sprocket cover off the bike and get him to put his air/impact wrench on it, nip it back up tight by hand ride home and complete the task. I thought KingKong was an American but the cupid stunt worked for Yamaha in the front sprocket nut department when they built my bike.
But what a great bike they are though, great for pottering about in town and great for tear arseing about down country lanes, basically a brilliant all rounder with a nod towards the retro look, I love it.
tommyardin
« Reply #9 on: 27 April 2016, 09:04:20 am »
The fact that Chris's nut rotates but does not actually come off does not bode well, if it was the threads in the nut that were gone the nut would come off easily, because the orifice in the nut would be larger. It points to the threads on the shaft being stripped  :'( I really hope for his sake that is not the case as I understand it is a complete strip down to replace the shaft.
Although one member in here tack welded the nut on his shagged shaft and has ridden the bike for a number of years like that. (Not ideal though, but a solution as a cheap but practicle workaround)
Good luck Chris keep up posted as to how it pans out  :thumbup
« Reply #10 on: 27 April 2016, 10:41:33 am »
1988
Okay, i'll meet you half way and we'll call it a 1998.
FAZERSHARP, are you reading this?  :pokefun  :rollin
« Reply #11 on: 27 April 2016, 12:31:50 pm »
 would be almost my age:)
Yep it's 98 typed it wrongly
« Reply #12 on: 27 April 2016, 12:49:59 pm »
1988
Im here ---- before we go to deathcon 5
Chrischristopherson could you tell us (me) how many miles your bike has done
« Reply #13 on: 27 April 2016, 12:55:10 pm »
1988
What's that gotta do with the price of fish?  :lol
« Reply #14 on: 27 April 2016, 01:12:58 pm »
1988
Ok I am waiting for him to say 24k or more in which case the nut will of been off to already replace the sprocket---- meaning it is not a factory fitted un touched nut that has came loose, and therefore still maintaining my pet theory.
So chris do you actually know if it has had a new chain and sprocket set in the past
« Reply #15 on: 27 April 2016, 01:49:39 pm »
28k but the nut it's still there just loose a bit.
It's original nut and sprocket looks as it was changed
« Reply #16 on: 27 April 2016, 01:53:14 pm »
Will wait for new nut and then see
I am optimistic
« Reply #17 on: 27 April 2016, 02:00:57 pm »
Ok thank you for the info
Just as I thought 28k and already been replaced
DARRSI. are you reading this?  :pokefun (I believe it goes  ) :nana
« Reply #18 on: 27 April 2016, 02:03:29 pm »
chris
for some background info on this banter see here http://foc-u.co.uk/index.php/topic,19504.msg225613.html#msg225613
« Reply #19 on: 27 April 2016, 04:46:52 pm »
The sprocket may have been replaced, but still the original nut!
Hardly surprising it's done over 24K on an 18 year old bike!
« Reply #20 on: 27 April 2016, 05:10:44 pm »
Here's some competition for the later-bikes-have-an-undersized-shaft theory:
a) the nut was underspecified
b) early Fazers had it glued on with a ridiculously strong threadlock (hence the need for a scaffolding pole extension on the socket to shift it )
c) Yamaha realised they'd made the bond too strong and switched to a different compound on later Fazers which proved to be inadequate
d) when owners/mechanics replaced the sprocket, the thread was contaminated with oil and they didn't use high-strength superglue hence subsequent failures on early bikes
e) Yamaha's instruction to dealers regarding shaft replacement relied on a measurement of the diameter of the threaded portion not because they'd made some too small, but as a means of determining whether the thread had been too badly damaged by the loose nut and/or sprocket.
« Reply #21 on: 27 April 2016, 05:40:24 pm »
You still don't get it do you - its not the nut its the output shaft on 99 onwards.
We are yet to find a 98 with an un touched nut that has had the nut come off on its own
« Reply #22 on: 27 April 2016, 05:44:47 pm »
Also my pet theory is that the original 98s shaft was only produced in 1 factory and it was after 98 when production stepped up that other factory's were brought online to produce the shafts which were undersize. So all 98s are ok and thereafter its a game of chance where your shaft was made as to whether or not you have the issue because remember that not all 99 onwards have the issue. And ones yam found out they made sure the shaft spec on new bikes was correct
tommyardin
« Reply #23 on: 27 April 2016, 06:27:46 pm »
Now it seems we have a conflict of interest here (Or am I being thick, answers on the back of a sealed white envelope to P O Box 999 Basingstoke)were some of the shafts manufactured undersize or iare some undersize because of a loose nut chattering and wearing the apex off the top of the shaft threads.
I was born in 1947 and my Mrs reckons my shaft is undersized, and my nuts chatter as well. :eek [size=78%]  [/size]
« Reply #24 on: 27 April 2016, 06:48:14 pm »
IT'S definetelly old small nut (really rusty) but I can't be sure if it's original
