Date: 07-05-26  Time: 01:17 am
Author Topic: Sprocket gearing  (Read 16295 times)
matt7chunk
Sprocket gearing
« on: 25 April 2016, 05:51:02 pm »
Hey
What gearings are you guys using and what do you all think are the best?
Need to change chain and sprockets but not sure if I should keep stock or not
Sent from my GT-I9300 using Tapatalk
matt7chunk
Re: Sprocket gearing
« Reply #1 on: 25 April 2016, 05:51:42 pm »
Woops sorry for double post
« Reply #2 on: 25 April 2016, 07:14:14 pm »
I have kept it standard, never saw any reason to change it  :eek
misterjayb1
« Reply #3 on: 25 April 2016, 07:14:40 pm »
Iv only ever gone +1 or -1 from standard on the front sprocket.. I guess it would depend on the advantages you wish to gain from changing gearing and also your riding style.. Performance, economy etc..
« Reply #4 on: 25 April 2016, 07:48:18 pm »
So is it +1 on the front to get a little more umph 0-60 with the trade off of higher revs in 6th or will just 1 tooth not be enough to notice
Slaninar
« Reply #5 on: 28 April 2016, 06:01:25 am »
I used to have stock front with a larger rear chainring. That was nice for in town riding - let me stay in 2nd gear as long as I'm not standing still.
For open road, speed limit is 80 km/h so that was doable in 6th gear at small revs, in spite of the "shorter" gearing.
joebloggs
« Reply #6 on: 28 April 2016, 06:25:45 am »
How big was your rear sprocket?
Any chain length issues?
Slaninar
« Reply #7 on: 28 April 2016, 08:06:03 am »
I really can't recall right now. It was some 5 or something teeth larger. Took about 500 revs more to ride at the same speed.
Didn't notice any chain length issues, since the chain was sized to suit the chainrings - they were changed along with the chain by the prevoius owner. When I changed drivetrain chain and chainrings, I went to stock - and regretted it a bit.
joebloggs
« Reply #8 on: 28 April 2016, 08:44:31 am »
That's proper oversize  :D
Thanks
Val
« Reply #9 on: 28 April 2016, 12:35:22 pm »
I have -1 front 14 tooth front. That gives me little more torque and more faster acceleration, but makes my revs a little higher than standard and top speed little lower. About 300 revs more in 6th and 500 revs more in 2nd. Acoording to gearing commander http://www.gearingcommander.com/ that also makes my top speed lower 133mph compared to 143mph standard.
I really do over 100 so not bothered at all  :lol
That improves the acceleration in foots per second from 22 to 25 ft/s2 according to:
http://motorcycleperformanceanalyzer.com/yamaha/fzs-600-fazer-1998/
14 tooth
9100 rpm
59mph
500 lbf
25 ft/s2
Standard:
9100 rpm
62mph
460 lbf
22 ft/s2
If you change ratio 1 tooth change in front equals 3 tooth change rear. Means -1 front = +3 rear. You can do both obviusly if you want bigger impact.
Moto gymkhana guys go say for smaller front and really huge rear sprocket. That gaves them huge acceleration and more torque. Not very suitable for road riding.
I am thinking about doing gymkhana at some point and have the 51 rear sprocket ready. I reckon because its not very drastical change I'll be able to ride on the road with it too  :)
Finally you can go the other way to have bigger front and smaller rear. This will make your ride more relaxed with less revs on the motorway.
If you want relaxed ride I suggest the Fazer 600 is not for you  :lol
The whole point of small capacity IL4 engine is to go in high revs and scream. It is detuned supersport engine.
You need relaxed ride get low revs twin engine. Like Honda Dullville  :rollin
Or really big liter bike one like FZS 1000. Or Bandit 1250. These are relaxed motoway tools if you want them to be.
Slaninar
« Reply #10 on: 28 April 2016, 03:10:32 pm »
The less teeth, the less the sprockets (and the chain) last. I'd rather go + than -. Especially wouldn't reduce the, already small, number of front sprocket teeth.
« Reply #11 on: 28 April 2016, 03:44:00 pm »
So you are saying instead of - 1 front for some more acceleration it would be best to go +3 back for exactly the same effect
Slaninar
« Reply #12 on: 28 April 2016, 03:51:14 pm »
Exactly.
The same as for faster gearing, better to add +1 up front (and cheaper), than to deduct at the rear.
Val
« Reply #13 on: 28 April 2016, 07:36:35 pm »
It is more complicated than that. There is something called Same Tooth - Same Link. Means how many revolutions the chain makes before hitting the same tooth. For the standard front is 3. If you do -1 you actually have better Same Tooth - Same Link it will be 7. The biggest Same Tooth - Same Link number means less wear.
It is true that smaller front sprocket means more Tooth-Links contacts. Standard is 2628 per mile. With my -1 that gets worst 2816 Tooth-Links contacts.
In practice that means your front sprocket will worn a little faster. If you service your chain slack properly it will need several chains to run on the same sprocket in order this to have any effect.
If you do rear +3 you will have 2792 Tooth-Links contacts per mile. Means no difference than -1 front in wear terms.
joebloggs
« Reply #14 on: 28 April 2016, 08:01:20 pm »
+ 10 on the rear means big wheelies so less front tyre wear.................... :D
Slaninar
« Reply #15 on: 28 April 2016, 08:47:13 pm »
Good poin! Now, less teeth means sharper chain angle as well as less links sharing load at the same time. That's critical for the front, the rear one is pretty big in all combinations.
So 7 TLC, instead of 3, vs more teeth to share the load. I have no idea which is better.
Val
« Reply #16 on: 29 April 2016, 09:27:06 am »
I have no idea too just reading gearingcommander stuff  :lol
The reason I have done the front only was when I tried to fit the new chain and the bigger rear too there was no place left and I was not able to put the chain because of the bigger rear. According to the specs it must fit but it wasn't.
Slaninar
« Reply #17 on: 29 April 2016, 10:46:45 am »
From my vast cycling (riding and mechanic) experience - smallest sprocket in the drivetrain suffers the most and having bigger sprockets significantly increases drivetrain longetivity.
On motorcycles, I've seen that front sprocket gets worn while the rear looks OK (provided the chain is changed in time - when the chain gets "stretched" - it starts rapidly wearing the rear sprocket as well).
joebloggs
« Reply #18 on: 29 April 2016, 12:39:29 pm »
14 tooth
9100 rpm
59mph
500 lbf
25 ft/s2
Standard:
9100 rpm
62mph
460 lbf
22 ft/s2
14-51 gives some impressive figures, can't imagine it would do much for your fuel consumption
« Reply #19 on: 29 April 2016, 12:50:46 pm »
That's what I was thinking -1 on the front wont make much difference to the rear wheel position along its ajustment slot, but to get the same result by just doing the rear sprock by going +3 then surly that would be just too much for the chain to fit.
Is there such a thing as -1 front and +1 back
Val
« Reply #20 on: 29 April 2016, 01:42:37 pm »
Any combination is possible. The only thing you needs to check in http://www.gearingcommander.com/ is does that combination have bad same link same tooth combination. -1 14tooth and +1 49 is a good combination.
Bad combinations happen when number of the chain links (we have 110 links in FZS 600) can be divided by the number of the sprocket tooth.
Say front 11 tooth and rear 55 tooth is very bad. Actually it is the worst one that you can have. It gives same link same tooth number 1 for BOTH sprockets. Means on each rotation absolutely the same tooth front AND rear will hit the same chain link.
« Reply #21 on: 29 April 2016, 02:19:21 pm »
All of that same link-same tooth never even crossed my mind.
What does the standard fzs 600 combo give
Val
« Reply #22 on: 29 April 2016, 07:59:20 pm »
Standard has 3 front and 24 rear. Doing -1 front makes the front 7. Doing +1 rear makes the rear 49. Much better than standard  :)
Slaninar
« Reply #23 on: 30 April 2016, 07:19:21 am »
With a +3 rear it's 51 at the back, but you might have to get a chain that's riveted together and make it one link longer than standard. Maybe.
As far as sprocket wear goes, the front sprocket is critical - rear one outlives the front by far any way. And not only due to same link same tooth effect I believe.
matt7chunk
« Reply #24 on: 30 April 2016, 10:03:11 am »
Some great info here , all I want to do is bring the revs down a tad at 70, would -2 rear be a bad thing?
Sent from my iPad using Tapatalk
