Date: 08-05-26  Time: 04:49 am
Author Topic: Loss of tyre pressure  (Read 8965 times)
redfox1
« on: 17 April 2016, 07:05:24 pm »
Hi everyone,Just a quick question-how common is it for the wheels to  become corroded ?.I'm asking as both my front and rear tyres are losing roughly about 1psi a day.I have had them refitted by a tyre tech,but they still leak about the same amount,and he did mention possible corrosion-has anybody else had this problem,and short of new wheels,is there anything else I can do?
Val
Re: Loss of tyre pressure
« Reply #1 on: 17 April 2016, 07:44:46 pm »
Val
« Reply #2 on: 17 April 2016, 07:46:05 pm »
Your Fazer is very new to have that. And I never heard that hapenning on even older Fazers. Theoretically is possible. What worries me your tyre "tech" uses the word "possible"? That means he has done not good job finding the leak. Does he ever immersed the whole tyre in a water tank to find the leak at all?
If not you need better tyre tech.
There may be zillion other thinks too. Like valves. Because of clamp weights. Cracks on wheels. Different tyre punctures.
If the corrosion in the beads is the problem, most tyre outlets will take off the tyre, clean off the worst of the corrosion and refit the tyre using a sealant that is specially made for the job.
Obviously your tyre "tech" has not find the leak and has not done the cleaning and sealant bit does he?
slappy
« Reply #3 on: 17 April 2016, 07:52:11 pm »
Check the tyre valve, make sure the inner part is screwed in correctly. Smear a bit of spit over the valve , after removing the cap obviously, see if there are any bubbles.Is the tyre seated correctly on the rim?
As for corrosion, possible but  I think it would be unlikely.
redfox1
« Reply #4 on: 17 April 2016, 08:27:28 pm »
Thanks,guys.I think the tech did use some sealant cos I can see the remains of it on the wheels.Done the spit test myself,and could see nothing-I guess I might go back to see if they could have another go,or maybe take it to another garage,but original garage is really local,so it will be harder,but the bike is otherwise great,so I suppose it's no real chore to put myself out! :)
slappy
« Reply #5 on: 17 April 2016, 09:20:05 pm »
Are you sure its sealant and not just remains of  whatever stuff they used to help tyre slip onto rim?
Where I get my bike  tyres fitted he uses a soaplike lube to ease them on better and it leaves a white residue.
redfox1
« Reply #6 on: 17 April 2016, 09:40:05 pm »
Yea,that's right,the residue is white-does anybody know what colour the sealant is?-Problem is,this tyre fitter comes highly recommended round here and is normally quite trustworthy-but something's not quite right!
Bretty
« Reply #7 on: 17 April 2016, 10:06:08 pm »
Ever considered filling the tyre with an off the shelf sealant (like slime) yourself?
I'm just putting that out there, I've never used the stuff, but I'm considering putting a can under the seat for some European touring I have planned.
I have a slow leak on my rear. I found today it was 21psi so inflated it back to 42, I'll check it next weekend and make a plan.
I also found the rear tyre has a 90degree valve and the front is straight so I couldn't use the compressor at my local garage and will but an emergency adaptor for it.
bandit
« Reply #8 on: 17 April 2016, 10:32:55 pm »
Redfox, clean the white residue off & make up thick washing up liquid/water mix & apply with a paintbrush between tyre/rim,look for bubbles,also check tyre valves for cracks or leaks from the base where it goes through the wheel.
redfox1
« Reply #9 on: 18 April 2016, 06:47:58 am »
Good idea-it's the fact that both tyres are both leaking at once which makes me doubt corrosion-they're year-old BT 23's which I've always had a problem with retaining pressure-will check the rims with the washing-up water to see if I can see anything
« Reply #10 on: 18 April 2016, 07:36:19 am »
The slime stuff works very well, i had a slow leak in my rear tyre, which still had life left in it so i gave it a go.
Few months down the line i heard a pop one morning and saw a large screw had gone in at a funny angle.
Tyre didn't deflate at all so i rode to bike tyre place a few miles away and got mugged off for a new T30 as it was the best one they had in stock.
They won't repair a tyre with this stuff in, because it's just too messy, and they'd have trouble using glue so it's way too much effort, but it'll certainly get you out of trouble if touring.
Can be a bugger to put in the valve though, it's lumpy so you need something to poke it down with and preferably an air line to use as well.
Val
« Reply #11 on: 18 April 2016, 11:11:35 am »
The sealant is yellow. Also it is important to clean well the corrosion on the beads before apply the sealant if that is the reason for the leak.
BBROWN1664
« Reply #12 on: 18 April 2016, 11:44:29 am »
did he replace the valve stems? They are a known failure point.
« Reply #13 on: 18 April 2016, 12:07:53 pm »
Very possible the valve has not been changed for a long time. They do perish and leak, badly perished one can break down suddenly.
Fazer rims are pretty good lasting and unlikely to be the source of the leak.
Don't go putting any crap without finding the problem first.
flakey
« Reply #14 on: 18 April 2016, 06:59:12 pm »
have your tyre fitter remove the tyre, replace the valve, clean up any corrosion on the wheel and then refit the tyre using the bead seal black sealant (like liquid rubber), rebalance your wheel, your problems should be solved, shouldnt cost much at all maybe £10 piss easy job for a tyre fitter. even the likes of ATS or national tyres or bathwick might do it
redfox1
« Reply #15 on: 18 April 2016, 07:58:57 pm »
Yep-deffo going back to the tech to see if he can fix-this time I'm going to ask where any possible corrosion is,and see if it can be addressed.Since yesterday the back tyre lost about 2 psi,front wasn't so bad,but both still losing pressure,so I've no alternative-Thanks for all the useful advice,folks :thumbup
redfox1
« Reply #16 on: 19 April 2016, 05:58:53 pm »
Just a quick update.Spoke to the tyre tech,who told me bring the bike back in.However,he said the wheels were corroded,and also that,if all else fails,he'd consider putting tubes in!-Now that's novel.Has anybody else heard of tubes under tubeless tyres?!
NorthWestern
« Reply #17 on: 19 April 2016, 06:22:32 pm »
They must be proper corroded... I have seen some in a real state and they are fine at keeping pressure.  Mine are not the best and are fine, the beads usually manage a decent seal.  Mine have both leaked at the valve Base.  A quick squirt with oil and spinning them got me to the next set of tyres when I replaced the valves.
Sent from my SM-G935F using Tapatalk
« Reply #18 on: 19 April 2016, 07:35:00 pm »
Not all tubeless tyres are suitable for putting tubes in. :eek
I have never seen a fazer rim so badly corroded it would leak unless the tyre was fitted without tyre soap. The tyre soap not only aids putting on the tyre also acts as a bit of a sealant. I still think it is the valve needs changing and if it was changed he may have fitted it dry or could also be a bit of dirt stuck on the rubber of the valve core.
robby boy
« Reply #19 on: 20 April 2016, 12:16:36 am »
Personally I would not recommend putting tubes in, if you get a nail in the tyre it will deflate at a much higher rate with a tube and if that happened on a spirited ride going into a corner who knows where you might land, I would check the valve stem where it comes through the wheel, if no leak there try round the rim and round the tyre, use warm water with a dash of fairy, (warm water sticks to the rubber and does not run off like cold) if it is round the rim clean all corrosion off and use the liquid rubber like others have already said.
joebloggs
« Reply #20 on: 20 April 2016, 04:17:28 pm »
You could always over inflate them by say 3psi and pump them up once a week, wouldn't be the end of the world!
redfox1
« Reply #21 on: 20 April 2016, 06:22:53 pm »
Slaninar
« Reply #22 on: 21 April 2016, 05:01:15 pm »
Have the valve checked. Could be leaking beside the valve itself. Rubber becomes damaged, or the valve is not well seated in the wheel's rim. New valve is not expensive.
Since the tyre would be taken off when doing that, check the tyre as well for any punctures, and make sure the rim is clean and some glue is placed on it before mounting the tyre back.
Good tyre service can do it all in no time.
