Date: 26-05-26  Time: 00:11 am
Author Topic: Yellow colour match  (Read 8778 times)
Yellow colour match
« on: 06 April 2016, 01:37:02 pm »
Hello Foccers, can someone confirm that the correct colour match for my bike is reddish yellow cocktail. Bought a touch up pen pack from wemoto and it looks nothing like it. It's coming up much too dark and stands out like a sore thumb. I know the colour may change once it's lacquered but it's got to look similar to start with. Am thinking I'm better off just matching it with a car colour from Halfords. Don't know if the second photo has anything to do with the paint code.
Any ideas ?
Grayo
Re: Yellow colour match
« Reply #1 on: 06 April 2016, 02:00:06 pm »
I would match it on the RS Paints website and order from them. Bit more expensive but at least it will match.
Here you go.
http://www.rsbikepaint.com/en-gb/colours.php#makeid=163&modelid=4601&prodyear=2003
bludclot
« Reply #2 on: 06 April 2016, 05:48:49 pm »
Even better than RS would be a trip to a good local paint factor - they can mix up some paint for you to an exact match to whatever you put in front of them. This then takes into account any fading or other colour changes that may have occured since the piece that you want to touch in was painted originally. RS can only supply you a factory colour match unless you take your bike / pieces to them!
I use Express Paints in Portsmouth - they keep adding tiny amounts of colour to a base and dry it under an infra red lamp thing and until the match is spot on. The aerosols that Express Paints supply are considerably easier to use than RS aerosols. While on the subject of aerosols the Pro-XL range of lacquers etc. is astonishingly good and easy to use. I haven't used Halfords products for some years, (so they may have improved) but compared to speaicalist paint factor products they used to be very poor indeed, difficult to apply and ran so easily that any sort of flat surface quickly had more runs than Geoffery Boycott.
« Reply #3 on: 06 April 2016, 06:56:28 pm »
The Official Yamaha Name is "Reddish Yellow cocktail 1" RYC1 The one at the end is a shade number and needs to be included when specifying the paint colour.
« Reply #4 on: 06 April 2016, 08:05:28 pm »
Well, according to the package, that's what they sent but as you can see it's so dark. Looks even worse on a chip, almost a mustard colour.
Might send it back if I can and as suggested, take a trip to a local paint factor.
« Reply #5 on: 06 April 2016, 08:11:17 pm »
Possible the yellow on the bike is faded, is it out in the open much? Check under the tank near the edges to see if the colour looks a closer match. If not contact the suppliers
« Reply #6 on: 06 April 2016, 08:27:43 pm »
Always put away under cover since I've owned it and the belly pan is brand new OEM part ready painted and matches the rest perfectly.
Just been on th RS website and they are listing another yellow "performance yellow" still a reddish cocktail.....Starting to get confusing isn't it
Enter your motorcycle details to find your colour
 make:select makeAdlerAdlyAermacchiAJSAmbassadorApriliaArielArmstrongArmyAtalaBenelliBetaBianchiBimotaBMGBMWBown BridgestoneBroughBSABuellBultacoCagivaCan AmCaproniCCMColnagoCondorCorgiCottonDerbiDKWDMWDotDouglasDucatiElswickExcelsiorFanticFran. BarnettFreraGarelliGas GasGileraGreevesHarley Dav.HeinkelHendersonHeskethHondaHudsonHyosungIndianIsomotoItaljetJailingJamesJawaJESJinlunKangdaKaw asakiKTMKymcoLambrettaLaverdaLegnanoLMLMaicoMalagutiMalancaMatchlessMBKMMMobyletteMondialMontesaMor iniMoto GuzziMoto Hisp.MotomMotosacocheMV AgustaMZNimbusNormanNortonNSUOssaP&MParillaPetronasPeugeotPhillipsPiaggio/VespaPremierPuchRace ReplicaRaleighRickmanRiejuRoyal EnfieldRudgeRumiSachsScorpaScottSertumStandardSterziSunbeamSundiroSuzukiSWMSYMTGBTritonTriumphUralV elocetteVelosolexVesrinoVictoryVincentVoxamWermachtYamahaZundapp  model:select modelAC 3 175ccAerox RAll colours listed by codeAS 1AS 2AS 3AT 2AT 2 (USA)AT 2MAT 3AT1 BAT1 BMXAT1 CAT1 MXATMXBreezeBT 1100 (Bulldog)BW 50 (Bi Wizz)BW 50/80/200/350BW'S 125BW'S 50BW'S NGBW'S SpyC3 ScooterCS 3 BCS 3 CCS 5 ECS 50 (Jog R )CS 50 (Jog RR )CT 1 175 (Trial)CT 2CT 3CW 50 (Spy)CW50RS (Bi Wizz)CW50T (Bi Wizz)CY50 (Jog In)Cygnus X 125D'elightDS 6 BDS 6 CDS 7 250DT 1DT 100DT 125DT 125 LC IIIDT 125RDT 125R EvertsDT 125XDT 175DT 1BDT 1CDT 1CMDT 1EDT 1FDT 1MXDT 1SDT 2DT 200RDT 250DT 2MDT 3DT 360DT 400DT 50DT 50 MXEC-03EnticerEW 50 (Slider)Fazer 8 ABSFJ 1100FJ 1200FJ 1200 (3CV)FJ 1200 (ABS)FJ 600FJR 1300FJR 1300AFJR 1300AEFJR 1300ASFS 1FS 1 - SE (Chopper)FS1FS1 M DXFS1 SEFS1E 50FS1E 50 DXFZ 1 (Fazer)FZ 1 (Fazer) ABSFZ 400 (Import)FZ 6 (Fazer)FZ 6 (Fazer) S2FZ 6 (Fazer) US ImportFZ 600FZ 700FZ 750FZ 750 (Import)FZ 750 5V (Genesis)FZ 8FZ 8 (50th Anniverary)FZ 8 ABSFZ 8 TouringFZR 1000 (Exup)FZR 1000 (Genesis)FZR 1000 (Pre Exup)FZR 1000GFZR 1100 (Exup)FZR 250RFZR 400FZR 400 (Import)FZR 400RRFZR 400RR (Import)FZR 600FZR 600RFZR 600R (Cocktail Colours)FZR 600R (Import)FZR 750FZR 750 (Genesis)FZR 750R (OWO1)FZS 1000 (Fazer)FZS 600 (Fazer)FZS 600S (Fazer)FZX 750 (Fazer Import)G5SG6SG7SGiggle 50GS 650GT 1GT 80GT MXAGT MXBGT MXCGT MXDGTS 1000HS 1BHT 1HT 1BHT 1MXIT 125IT 175IT 200NIT 250IT 400IT 425IT 465IT 490NJT1JT2JT2 MXL5TALB 50LB 80IIACLB 80IIADLB 80IIHCLB 80IIIDLT2LT2MLTMXMorphousMT -125MT-01MT-03MT-07MT-09MX 100MX 125MX 175MX 250MX 360MX 400Neo's 4Neo's EasyPW 50PW 80QT 50SR3R5R5BR5CRaiderRazzRD 100LS2RD 125RD 125DXRD 125LCRD 200RD 200DXRD 250RD 250LCRD 250LC (Kenny Roberts Replica)RD 350RD 350 LCRD 350 LC (Kenny Roberts Replica)RD 350 LCFRD 350 YPVSRD 350B (US Import)RD 350RRD 400RD 400 Daytona SpecialRD 50 MRD 500LCRD 500LC MarlboroRD 60RD 60BRD 80LCRDX 125Riva 125Roadliner 1850Roadliner 1850 (Midnight)Royal Star Venture SRS 100RS 100 (Import)RS 125RS 125DXRS 200RT 1RT 100RT 180RT 1BRT 1B EnduroRT 1B MXRT 1MRT 1MXRT 2MXRT 3RXS 100RZ 350N (U.S Import)RZ 500RZV 500 (Import)Salient MopedSC 500ScooterSeca 750SH 50HSR 125SR 250SR 250 SpecialSR 400SR 500SRX 250SRX 400SRX 60SRX 600Star StrykerStratoliner 1850Stratoliner 1850 (Midnight Edition)SZR 660 (Super Single)T 50T 80 (Townmate)T MAXT MAX (Black Max)T MAX (Bronze max)T MAX (Night Max)TD 2 (Racer)TDM 850TDM 900TDR 125TDR 250TricityTRX 850TT 500TT 600TT 600 ETT 600 RTT 600 RETT-R 110TT-R 125TT-R 125ETT-R 125LWETT-R 225TT-R 250TT-R 250 (Import)TT-R 50TT-R 600RTT-R 90TW 125 (Trailway)TW 200TX 500TX 640TX 650TX 750TY 125TY 175TY 250TY 350TY 50TY 80TZ 125TZ 250TZ 350TZR 125TZR 125RTZR 250TZR 250 (Reverse Cylinder)TZR 250 (V Twin)TZR 50U5U7EV 80V MAXV MAX (Import)V MAX (US Import)V MAX 1679ccV MAX Limited EditionV Star 1300V Star 1300 TourerV Star 250V Star 950V Star 950 TourerV Star SilveradoVance & Hines (Race Replica)Ventura 1300Ventura Royal 1200Versity 300VinoVino 125Vino ClassicVirago BoosterVirgin Cola Race ReplicaVP 300 (Versity)WR 125RWR 125XWR 250WR 250FWR 250RWR 250XWR 400FWR 426WR 426FNWR 450FWR 500X City 125X City 250X Max 125X Max 125 (Black)X Max 125 SportsX Max 250X Max 250 (Black)X Max 250 SportsX Max 400XC 125XC 125E VityXC 125R (Cygnus)XC 200XenterXJ 400 (Diversion Import)XJ 550 (Maxim)XJ 6XJ 6 (Diversion )XJ 6 (Diversion ) F ABSXJ 6 SPXJ 600 (Seca Import)XJ 600F (Pre Diversion)XJ 600NXJ 600S (Diversion)XJ 650XJ 700XJ 700NXJ 700XNXJ 750XJ 900XJ 900S (Diversion)XJR 1200XJR 1200 (Roberts Replica)XJR 1300XJR 1300SPXJR 400 (Import)XN 125 (Teo`s)XP 500 (T Max Black Max)XP 500 (T Max)XQ 125 (Maxster)XS 1100XS 1100EXS 1100GXS 1100JXS 1100MLXS 1100SFXS 1100SGXS 1100SHXS 250XS 360XS 400XS 400 dohcXS 400 SEXS 500XS 650 BXS 650 GXS 650 HXS 650 SEXS 650 SFXS 650 SGXS 650 SJXS 650 SKXS 650 SPXS 750 DXS 750 EXS 750 FXS 750SEXS 750SFXS 850GXS 850HXS 850SGXS 850SHXS1XS1BXS2XTXT 1200Z Super Tenere ABSXT 125RXT 125REXT 125XXT 225XT 250XT 350XT 500XT 550XT 600EXT 660RXT 660XXT 660Z (Tenere)XTZ 600 (Tenere)XTZ 660 (Tenere Import)XTZ 660 (Tenere)XTZ 750 (Super Tenere)XV 1000 (TR I)XV 1000 (Virago)XV 1100 (V Star Classic)XV 1100 (V Star Custom Midnight)XV 1100 (V Star Custom)XV 1100 (V Star Silverado)XV 1100 (V Star)XV 1100 (Virago Import)XV 1100 (Virago)XV 125 (Virago)XV 1600A (Road Star Millenium)XV 1600A (Road Star)XV 1600A (Road Star) (Midnight)XV 1600A (Silverado)XV 1600A (Wild Star)XV 1700 (Road Star Midnight Silverado)XV 1700 (Road Star Silverado)XV 1700 (Road Star Warrior Midnight)XV 1700 (Road Star Warrior)XV 1700 (Road Star)XV 1900A (Casual Full Dress)XV 1900A (Midnight Star)XV 240 (Virago French Import)XV 250 (Virago)XV 250S (Virago)XV 400 (Virago Import)XV 535 (Virago Import)XV 535 (Virago)XV 535DX (Virago)XV 535S (Virago)XV 650 V Star ClassicXV 650 V Star CustomXV 650 V Star Custom (Midnight)XV 650 V Star SilveradoXV 700 (Virago Import)XV 750 (US Virago)XV 750 (Virago)XV 750S (Virago)XV 750SEXV 950XV 950RXVS 1000A (Drag Star Classic US Import)XVS 1100A (Drag Star Classic)XVS 1100A (Drag Star Classic) (US)XVS 1100A (V Star Classic)XVS 1100A (V Star Custom)XVS 125 (Dragstar)XVS 1300 CustomXVS 1300A (Midnight Star Tourer)XVS 1300A (Midnight Star)XVS 250 (Dragstar)XVS 650 (Dragstar Classic)XVS 650 (Dragstar)XVS 650 (Dragstar) (German Import)XVS 650A (Drag Star Classic)XVS 650A (V Star Classic)XVS 650A (V Star Custom)XVS 650A V Star Classic (US)XVS 950A (Midnight Star)XVZ 12DN Venture RoyalXVZ 1300A (Royal Star Tour Classic)XVZ 1300A (Royal Star Tour Delux)XVZ 1300A (Royal Star)XVZ 1300A (Venture Midnight)XVZ 1300A (Venture Milennium Ed)XVZ 1300A (Venture)XVZ 1300AN (Boulevard)XVZ 1300AN (Tour Deluxe)XVZ 1300AT (Tour Classic)XVZ 1300TF (Royal Star Venture)XVZ 1300TF (Venture Star)XZ 550YA 6YAS 1YAS 3YB 100YBR 125YBR 125 (Custom)YBR 250YCS 1YCS 1 BonanzaYCS 2YCS 3EYCS 5EYDS 3 CatalinaYDS 3CYDS 5YDS 6BYDS 7 250YFM 660R (Quad)YFM 700R (Quad)YG 1YG5TYH 50 (WHY)YJ 1YJ2SYL1 100 (Twin)YL1EYL2YL2CMYM1YM2CYN 100 (Neos)YN 50 (Neos)YP 125 (Majesty)YP 250 (Majesty)YP 400 (Majesty)YQ 100 (Aerox )YQ 250 (Aerox)YQ 50 (Aerox R 50th Anniversary)YQ 50 (Aerox R GP1)YQ 50 (Aerox R Santander)YQ 50 (Aerox R)YQ 50 (Aerox SP)YQ 50 (Aerox)YQ 50 (Aerox) Ltd Ed Rossi ReplicaYQ 50 (Rossi Replica)YR 1 350YR 2YR 2CYR 5 350YSR 50YX 600 (Radian)YZ 100YZ 125YZ 175YZ 250YZ 360YZ 400YZ 426FYZ 450FYZ 490YZ 600TYZ 80YZ 85YZF 1000 Moto GPYZF 1000R (Thunderace)YZF 250FYZF 450FYZF 600YZF 600R (Thundercat US Import)YZF 600R (Thundercat)YZF 750RYZF 750R (Fast Orange Replica)YZF 750R SPYZF R 1YZF R 1 (50th Anniversary)YZF R 1 (Import)YZF R 1 (Kenny Roberts Inter colour)YZF R 1 SP (US Import)YZF R 125YZF R 125 (50th Anniversary)YZF R 125 (Rossi Race Replica)YZF R46 Ltd Ed. (Rossi Sun / Moon)YZF R6YZF R6 (50th Anniversary)YZF R6 (Import)YZF R6 (Kenny Roberts Inter colour)YZF R6 (US Import)YZF R7 (OWO2)YZR M1 Laguna SecaZestZest 80Zuma year of production:select year20012002200320042005  Note on Year of Production
The year you select should be the year of manufacture. This may not be the year of registration.  Select your colour scheme:  Reddish Yellow Cocktail #1/ Extreme Yellow / Black (with Pow...  Reddish Yellow Cocktail #1/ Extreme Yellow (Bike Colour) Power Black/Matt Black Metallic 2 (Frame colour)   Silver Tech (with Power Black/Matt Black Metallic 2 Frame co...  Silver Tech (Bike Colour) Power Black/Matt Black Metallic 2 (Frame colour)   Galaxy Blue Pearl/Dark Purplish Blue metallic L (with Low Gl...  Galaxy Blue Pearl/Dark Purplish Blue metallic L (Bike Colour) Low Gloss Black (Wheel Colour) Light Yellowish Grey #1 (Engine colour)   Power Black/Matt Black Metallic 2 Frame colour  Power Black/Matt Black Metallic 2 (Frame colour)   Yamaha Black / Performance Yellow/ Light Reddish Yellow Soli...  Yamaha Black (Bike Colour) Performance Yellow/ Light Reddish Yellow Solid #1 (Bike Colour)   Light Yellowish Grey #1 Engine colour
« Reply #7 on: 06 April 2016, 08:30:23 pm »
" Performance yelow "      :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin :rollin
Hedgetrimmer
« Reply #8 on: 06 April 2016, 08:34:17 pm »
No, he only rides it indoors  :lol
« Reply #9 on: 06 April 2016, 08:46:14 pm »
This is true......And it's still faster than Red's  :D
:finger
Exupnut
Yellow colour match
« Reply #10 on: 06 April 2016, 09:06:14 pm »
Its phish urinechrome yellow Darren so phish on it....I did when u weren't lookin...
« Reply #11 on: 06 April 2016, 10:04:40 pm »
I was doing my best to be nice to him, not wanting to ask if it made a buzzing noise :lol
« Reply #12 on: 07 April 2016, 04:11:48 pm »
Messaged them this morning, got this back the same day..... Customer service at it's very best  :thumbup
  New message from: wemoto (48,169)[/t]
   Hello
Thank you fro your email. i am sorry there seems to be a problem here. We have tried a different formula and tried to match with the photo you have sent this is not easy and i can not be sure this will be right but its the only other one we have. I will send this out today for you it will be two bottles as we cant see from the photo if it has a pearl affect . You will get one yellow and one pearl. I hope this is ok?
The main problem we have found is that yellow is such a fast colour in every way. It even dries fast making colour matching extremely difficult but then you know this as you ride a yellow bike and must have massive kahooners.
Many Thanks [/t][/t]
Exupnut
« Reply #13 on: 07 April 2016, 04:27:52 pm »
HAHAHAHAHAHHA PURE GENIUS!!!!
(Well......for a short bald twat anyway) ;-)
ste131
« Reply #14 on: 18 April 2016, 05:46:18 pm »
My Fazer 600 had Yellow Reddish Cocktail paint code and bought some aerosol paint from RS Paints and was perfect match.
