Date: 02-05-26  Time: 15:31 pm
Author Topic: Adjusting Gear Lever?  (Read 2419 times)
Percymama
« on: 23 March 2016, 05:38:47 pm »
Hi Guys
Finally managed to get out for a nice long ride on my 2002 Fazer 1000 today :)
All very nice except One issue
Changing up gears is damn painful! (wearing big boots)
I cant get my foot under the lever with ease, and keep getting false neutral too?
Is there a guide for adjusting the lever (pics would help - or  video)
I have had a LOT of bikes, but never needed to do this before, is it a Fazer thing?
The only other thing I can think of is not to wear my boots haha
Thanks ;)
markie_wales
Re: Adjusting Gear Lever?
« Reply #1 on: 23 March 2016, 06:16:09 pm »
Not by my Fazer but if it's like every other bike I've had to move the lever on, it will bolt onto a spline. Remove bolt, remove gear lever and put it back on in a different position on the spline. 5 min job.
Cheers
Markie
Red Ceri
« Reply #2 on: 23 March 2016, 06:48:32 pm »
It's even easier than that, at the ends of the gear change rod (Passes through the frame) there are two 10mm AF nuts, one is Left hand thread, once you've slackened both off you can turn the rod and this will adjust the position of the lever.
A lot of people have changed the lever at the gearbox end for an early R1 part, this reduces the movement required at the foot lever. Search the forum for previous posts for the year of the R1.
Percymama
« Reply #3 on: 23 March 2016, 06:51:05 pm »
Thanks Guys :)
I will take a look at the weekend ;)
Percymama
« Reply #4 on: 25 March 2016, 06:09:52 pm »
Well thanks to you guys, adjusting the lever was easy as piss haha
Now changing gears doesn't cause too much pain (broken Left leg and ankle with plates and pins means it aint ever gonna be painless lol)
But still getting spaces (false neutral) between gears though? change up to 3rd, and have to lift twice as its just flopping there between gears?
Any ideas?
PieEater
« Reply #5 on: 26 March 2016, 08:11:04 am »
I think as Red Ceri suggested you might benefit from the R1 linkage mod as this apparently takes some travel out of the lever and makes changes more positive. I've dug out a couple of threads regarding this for you;
http://foc-u.co.uk/index.php/topic,1052.msg7016.html
http://foc-u.co.uk/index.php/topic,2832.msg22478.html
Percymama
« Reply #6 on: 26 March 2016, 08:12:49 am »
Great!
Thanks mate :)
