Date:
29-03-26
Time:
03:34 am
Home
Media
old - Fazer Owners Club - old
front sprocket removal
« previous
next »
Print
Pages: [
Author
Topic: front sprocket removal (Read 1650 times)
oddfazerbod
Cager in Training
on:
18 March 2016, 02:39:57 pm »
chain and sprockets set bought cant get bloody nut off front sprocket .I take it it is opposite thread IE tighten it to loosen it ????? have done these on previous bikes 600 fazer should be no different should it. any advise welcome
cheers steve
Logged
GP Hero
Re: front sprocket removal
Reply #1 on:
18 March 2016, 02:51:04 pm »
Normal thread, anticlockwise to undo it.
Logged
His Dudeness
Naughty Corner
GP Hero
Reply #2 on:
18 March 2016, 03:49:54 pm »
If it's seized the only tool to use is an impact gun. Should zap it off no problem. Using anything else risks rounding the nut.
Logged
oddfazerbod
Cager in Training
Reply #3 on:
18 March 2016, 04:40:09 pm »
again fonts off knowledge on here will have another go. not removed any thing else so if not wanting to budge will pop it up to my local garage and use his impact gun
cheers guys steve
Logged
GP Hero
Reply #4 on:
18 March 2016, 04:44:31 pm »
One of my sprocket nuts managed to fuse itself on, took my mechanic ages to eventually remove it.
Better than it just falling off though i s'pose.
Presumably you've bought the upgraded 12mm nut to replace it with?
Logged
oddfazerbod
Cager in Training
Reply #5 on:
18 March 2016, 07:05:43 pm »
yahoo nut finally removed put my ratchet in a really long bar and used the extra length as a fulcrum to give more pulling power came of easy plus a mate turned up to put some weight on the brake pedal also a neat trick just behind front sprocket put a long nut and bolt through the chain it stops chain moving forward and locks it in place. so all good . No have not upgraded to 12mm but I will visit my dealer in the morning the gasket is US so need a new one of those it literally fell to bits all surfaces cleaned off so ready to go.
again thanks for help and did not know about 12mm upgrade have read up on this on the forum posts so all good
cheers steve
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
