Date: 10-04-26  Time: 01:18 am
Author Topic: white gunge on oil plug inner surface  (Read 2687 times)
shieldr
« on: 14 March 2016, 10:44:59 pm »
Bike is pulling great but i recently opened the oil plug to find some white gunge that i have not seen before. I am concerned the head gasket is away. Any thoughts, checks or tips on this much appreciated.
There is not much in the way of back pressure ie any puffing out of the oil fill hole.
Re: white gunge on oil plug inner surface
« Reply #1 on: 14 March 2016, 10:57:48 pm »
No worries whatsoever, just a cold thing.
Freaked me out first time i saw it, and i have pictures on here somewhere too.
Nothing to worry about, it's an oil/condensation mix that especially happens with short runs in colder air.
« Reply #2 on: 14 March 2016, 11:01:38 pm »
I'm out at the mo', do a search above for 'darrsi mayonnaise'.
That sounds so wrong.  :tape
shieldr
« Reply #3 on: 14 March 2016, 11:04:15 pm »
Phew. Thanks folks. Thought my wee engine was a right off.
bandit
« Reply #4 on: 14 March 2016, 11:04:50 pm »
Some times this can be caused by condensation if the bike doesn't get up to a good working temp if used on short trips in the colder weather, also check in the expansion tank for any white stuff floating in there will be a sign of blown head gasket.
shieldr
« Reply #5 on: 14 March 2016, 11:06:51 pm »
Should've said thanks Darrsi 😉
shieldr
« Reply #6 on: 14 March 2016, 11:27:24 pm »
Have washed it a couple of times since last week bringing it out of winter storage. My bet is new oil cap oring reqd. Hence the emulsified oil. Going to check for oil in coolant too Bandit; thanks.
« Reply #7 on: 15 March 2016, 08:02:41 am »
As i said it's just a cold air/engine thing, same as billowing steam/smoke out of the exhaust in cold weather, if you're not used to seeing it, it looks really menacing, but it's perfectly normal.
Just wipe the gunk off the cap and ignore it.
If the bike really did have a gasket leak you'd soon know about it.
« Reply #8 on: 15 March 2016, 08:16:23 am »
Have a read of this post too, for more gunge that can freak you out a bit that builds up in the air box.
http://foc-u.co.uk/index.php/topic,17271.msg199733.html#msg199733
